Post Add Topic Solved Help
Hi i was wondering how can i add a "Topic Solved" mod to the Milky Way Style Please
Cheers,
Aaron
aaron1988Send private message
Post Re: Add Topic Solved Help
You can follow the instructions for subSilver if you have them.
Hi i have subsilver LOL, do how do i add it as you havent added the instructiosn haha
No, MG means, that if you have the mod for "Topic Solved" then there should be instructions for changing "subSilver" things.
Follow these instructions also for "Milky Way".
