		  IronPhiraar
		  Buttons Not Appearing on Black Pearl
			Hi!
I used Black Pearl style on my page, everything work, but I can't see "new topic", "post reply" etc. buttons! That images is not missing, but it's not appear! My suggestion ist the bug in code. I can fix it, but I don't know  which template respond to this? I using the polish phpBB3 and polish forum, in ADM everything is done, images are visible and I have no messages of any problems. Plz help me, my site is:
 www.almighties.lua.pl
PS. Sorry 'bout my strange english ;p
	#1  Wed 25 Feb, 2009 14:58   |
		  Chaotic
		  Re: Buttons Not Appearing on Black Pearl
			IronPhiraar,
Your English is pretty good.
I believe there are quite a few topics about this and a few suggestions.  Try using the search feature here and I'm sure you'll find the answer you are looking for.
Welcome to Icy Phoenix by the way!
	#2  Wed 25 Feb, 2009 15:06   |
		  IronPhiraar
		  Re: Buttons Not Appearing On Black Pearl
			I searching this very long time, but I can't find where is this template. This is not problem with images, but with code, I remind.
	#3  Wed 25 Feb, 2009 15:11   |
		  IronPhiraar
			No, it doesn't. This tutorial show how to fix missing images, but my images is not missing, there is just nothing, like in this demo:
http://twojestyle.pl/phpBB3/index.php?s=314
PS: The buttons of "edit", online status, profile etc. are all visible, but "new topic"and "post reply" are not appear when I'm logged in or logged out.
Any suggestion? Before this i fix the bugs with register and login.
	#5  Wed 25 Feb, 2009 15:18   |
		  New Player
			try this:
create styles/black_pearl/imageset/pl and copy the content from styles/black_pearl/imageset/en in the pl directory and clear the cache
	#6  Wed 25 Feb, 2009 15:24   |
		  IronPhiraar
			I create a folder "pl" before and it still doesn't work. I place all images in this folder, I copy the .cfg file, I try to edit .cfg, I try everything! ;p In prosilver style everything aare visble and ready to use.
PS. the folder name is "PL" for sure, I check it.
	#8  Wed 25 Feb, 2009 15:29   |
		  New Player
			when you change your language to english the buttons are present?
	#9  Wed 25 Feb, 2009 15:34   |
		  IronPhiraar
			No, when I change the language of forum to "British english", buttons are not appear. I think this is bug with condition in template, when buttons are visible and when not.
I copy all images and templates from subsilver2 style to Black Pearl, just for try, and buttons are still not appear, so this is something wrong with .css files. Any suggestions?
I download all styles from this site, Icy Phoenix, and I can't see this buttons in any style.
	#10  Wed 25 Feb, 2009 15:37   |
		  novice programmer
			Have you tried to clear both server and local cache?
It helps many times....
	#11  Wed 25 Feb, 2009 18:14   |
		  IronPhiraar
			I try doing this, I clear the site, I place nwe installation of phpBB and Blacke Pearl with my modifications.
Without modifications no one buttons are appear.
	#12  Wed 25 Feb, 2009 18:18   |
		  novice programmer
I guess you mean you have modified icy template files?
	#13  Wed 25 Feb, 2009 18:23   |
		  IronPhiraar
			I modifed the login template and menu block template to fix register and login function.
I have the same problem:
 http://www.icyphoenix.com/viewtopic.php?f=32&t=3890
I create a "pl" folder into style/black_pearl/imageset
I copy the "imageset.cfg" form "en" to "pl" folder
I remove everything in this file and place there 2 lines:
img_button_topic_reply = button_topic_reply.png"
but it still doesn't work! Plz help me with this. ;/
	#14  Wed 25 Feb, 2009 18:48   |
		  novice programmer
check that one, please
	#15  Wed 25 Feb, 2009 20:04   |
| Link this topic |
	| URL |
	| BBCode |
	| HTML |
	 Similar Topics
	 Similar Topics
