Post How To Increse The Font Size Of Recent Block ?
Hi!,
I added a Recent Forum post block to IP Home page.This isssue is the recent forum posts Font size is small.How can i increse it?(pls refer Image 1)
And the other thing is how can i construct or can you pls direct me if this like of Recent block in IP(pls refer image 2)
Image 1
 crop
Image 2
 ans
system - View user's profileSend private message
Post Re: How To Increse The Font Size Of Recent Block ?
you need to open the tpl file for that which can be found in templates/your template/blocks/depending on the block you activated.... not sure which one it is as your pics are too small
then find gensmall in the code fand replace with either genmed or just gen (being the largest)
hope that helps
Successful.thankx lot
no problem
