Page 1 of 3
andrea75
 Re: 058 - 014 - KB Injection And Minor Fixes
Just a question.... now the portal is faster than older, but the calendar block now is not visible. It's an your choice or there is other way to insert it on portal? :0032:
____________ My Icy forum: www.lineameteo.it
#2 Tue 07 Nov, 2006 19:48 |
andrea75, can you try this?
OPEN blocks_imp_calendar.php
INSERT THIS CODE INSTEAD OF THE DEFAULT ONE
if(!function_exists(imp_calendar_block_func))
function imp_calendar_block_func()
global $phpbb_root_path, $phpEx, $template, $images, $lang, $board_config, $userdata, $_GET, $_POST, $db;
global $birthday_week_list, $birthday_today_list;
include($phpbb_root_path . 'mods/netclectic/mini_cal/mini_cal.' . $phpEx);
imp_calendar_block_func();
#3 Wed 08 Nov, 2006 22:47 |
AvrilBoi
Don't you have just the 014 patch? Because I've some modified files, and it would take so long to compare all the files included in the comulative patch with mines...it would be better to have just the patch number 14... if it is possible... thanx
#4 Thu 09 Nov, 2006 14:38 |
 Re: 058-014 - KB Injection And Minor Fixes
Added an attachment with only new files.
#6 Fri 10 Nov, 2006 00:40 |
andrea75
The calendar is come back, but has wrong events (now shows all events, past and future) and don't shown the birthdays information
But it's not true that no users has a birthday
#7 Fri 10 Nov, 2006 09:33 |
pepi
Hi
Have the same problem with calendar
#8 Sat 11 Nov, 2006 15:10 |
AvrilBoi
You can use winmerge http://sourceforge.net/projects/winmerge/ ...
It's really a good thing to compare files.
I know, infact i was gonna use it to compare files, but if they're too many to compare, it takes long time
Thank you.
#9 Sun 12 Nov, 2006 22:56 |
Master Sulu
Hi
I think that the problem is in the new index.php: some parts relating to calendar and birthday are missing.
Check out with winmerge, comparing it with the original index.php.
By the way, after this huge update I have a problem with the album. When i click the medium thumb in order to show off an image in its original size, the image is not entirely loaded, but I can see only a little strip at the top. Any way to fix it??
#10 Mon 13 Nov, 2006 19:23 |
The Album problem is not related to this patch.
Try having a look here:
http://www.mightygorgon.com/viewtop...ht=memory+limit
But the same problem has been discussed even on this site.
Regarding the calendar block, can you try this block and please let me know if the block is working fine?
Description: |
Calendar Block |
 Download |
Filename: |
blocks_imp_calendar.zip |
Filesize: |
1.81 KB |
Downloaded: |
502 Time(s) |
#11 Tue 14 Nov, 2006 01:05 |
pepi
Hi Mighty
does not show the calender box .........
but i have no upload the index.php and bbcode.php from the KB, BBCodes and Portal Fixes
then i habe installed any mods
pepi
#12 Tue 14 Nov, 2006 14:37 |
jocampo8
Thnx for the Update
#13 Wed 15 Nov, 2006 10:06 |
Zuker
And the old patch? (de 14 released before)
We have to aplied only this patch? (i've got a test forum where i didn't put any patch)
#14 Wed 15 Nov, 2006 13:22 |
Page 1 of 3
