Re: Ipb 2.3.6 To Icy Phoenix...
DWho wrote: [View Post]
Hi
In answer to your first question you need to convert to phpbb2 and then to Icy Phoenix...
Regarding wysiwyg editor... there are couple (I believe) mods for phpbb2 that will do this but you have to install them...
you can also use Xinha which is a firefox add on which does exactly the same and allows you to use it in any text box... but only if html is allowed...
The wysiwyg for Icy Phoenix... is bbcode but it can be used in so many different ways that the need for a html wysiwyg is not really necessary...
Thanks DWho for the help... i upgraded already to phpbb2, the upgrade to IP is inside the full release, no?
and i have to intall in the same DB or can i update it in a second DB but in the same server that phpbb isn´t in?
About the editor, all mods to phpbb2 are for IP too?
i liked the bbcodes, but the cool is the text instantly ready... you select bold, for example, and i see the text bolded in live, but it´s not anything emergencial...
very, very thank you for attention...
