Post Error Creating New Session
Error creating new session
DEBUG MODE
SQL Error : 1114 The table 'phpbb_sessions' is full
INSERT INTO phpbb_sessions (session_id, session_user_id, session_start, session_time, session_ip, session_user_agent, session_page, session_logged_in, session_admin) VALUES ('077642f3e1c8fa87e34ef566f087a73d', 1657, 1239053429, 1239053429, '5f4a0051', 'Mozilla/5.0 (Windows; U; Windows NT 6.0; it; rv:1.9.0.8) Gecko/2009032609 Firefox/3.0.8 (.NET CLR 3.5.30729)', 'forum.php', 1, 0)
Line : 220
File : sessions.php
What does it mean?????
Edited by Chaotic, Tue 07 Apr, 2009 01:29: Fixed the topic title to be more descriptive.
andrea - View user's profileSend private message
Post Re: HELP - HELP - HELP!!!
Are you using a phpbb board...?
Clear your session table in your phpmyadmin
DWho wrote: [View Post]
Done! ...fiuu...you've saved me, man...! Thank you!
No Problem
andrea,
HELP - HELP - HELP!!! is not a good description for your support topic.  It doesn't describe or sum up the problem you were having.  If another user happens to have the same problem you did and he uses search, he won't be able to find the solution because the information he needed is located in a topic titled "HELP - HELP - HELP!!!".
You are rather new here and this isn't a huge deal, but it saves the staff a ton of time not having to answer the same question over and over.  That's why we like our users to use search.
Thanks buddy!
Chaotic - View user's profileSend private messageVisit poster's websiteView user's personal gallery
Chaotic wrote: [View Post]
andrea,
Thanks buddy!
Yeah...I know...but it was a "panic fault"...
Next time I'll be more calm...
Thank you for not sending me the cops ...
Post Re: Error Creating New Session
As I said, it's not a huge deal since you are new.
Next time I'm sending Interpol!
