Post PhpBB3 Smiley Problem
My forum is http://studentink.info/forum/index.php , phpbb3  board , verison 3.0.0, Milky Way theme by  great MG ... so i see at some boards   that they have differnt smiley pack than my board ,and some extra smiley modes. They have option "View More  Smileys" and  option " Smiley Creator"   How can i have this options  ? Which mode i need and what i need to edit ?
Description: I want this two options on my board ! :)
Filesize: 41.15 KB
Viewed: 518 Time(s)
Description: My - default phpbb3 smiley pack
Filesize: 6.26 KB
Viewed: 262 Time(s)
masternkSend private message
Post Re: PhpBB3 Smiley Problem
Smiley Packs can be downloaded nearly everywhere on the net. Its simply just some gifs in the appropriate folders with a little setup in your ACP Use google to find some...
As for the smiley creator - well its a mod.
And for the image in the textarea. Well that simply can be done by editing your css file. Find the textarea definition inside the css and add the background-image variable with the path where the image is located...
For now i dont have links for ya (sorry). But with using search engines you should find those stuff as well. Or someone else post it here - or you wait a few hours more than i can post links^^
HuorSend private messageVisit poster's website
Ask the autor of that site.what's the link,please.I want that option too.maybe if you add more smilies than standard,that option (view more smilies) will show up.
Edit:i saw that this site has that option too.how do they do it?
Also where did they get those smilies?
zombie91Send private message
http://www.kolobok.us/index.php
