Post Forum Shows Less Topics Than Topics Exists
I will try to explain myself.
I have a subforum with 40 topics more or less (I see them in the moderator forum mode) but if you see as user, forum only shows 21.
This is the page: http://www.modmovil.com/themes-nokia-s60-3ed-vf62.html
I have tried to clear the cache, synchronize the forums in the DB, clear all topics with no text, but nothing works.
Do you have any idea about how to fix it?
Thanks a lot.
(I use IP 1.2.0.27c)
tiolalu - View user's profileSend private messageVisit poster's website
Post Re: Forum Shows Less Topics Than Topics Exists
first thing : I count 31
second:
have you set the Permissions to all users??
if you´ve got some without user access, they wan´t show in normal user access
Icy-Mods.com ( IP 2.0 RC-1)
I'm as administrator and I count 21 (+6 special topics), so I don't think it's permissions problem.
Thanks for your post!
Edit: I have discovered that if I change the Shows topics before... 1day, 1week... 1year I can see almost all (not the topics after 1 year), so I thinks there is a problem with the dates, but I don't know how to fix it because it doesn't shows all when I select show all topics.
