Post [Solved] Wordgraph/ Tag Cloud
Hey all,
I would like to have a small customization to the tag cloud/ wordgraph.
Ik you choose and click on a word, you get directed to for example:
http://www.icyphoenix.com/search.php?search_keywords=ownage
I would like to have a different amount of characters (now it is 100 I think...). I would like to change this to 1000. How do I change this?
Thanks in advance
OwnageWorld - View user's profileSend private messageVisit poster's website
Thanks for the useful Topic OwnageWorld:
DWho (07 August)
Post Re: Wordgraph/ Tag Cloud
You can change that going to
CMS- 3 columns - Wordgraph
go to edit then submit and you get the options to change number of words.
submit again and it should work.
but 1000 is a huge amount. try with 150-200. if not you will fill up a hole page
Icy-Mods.com ( IP 2.0 RC-1)
spydie wrote: [View Post]
Thanks for the input!
But that is not really my question...
I would like to know, and especially for the output of a search, how to change that number of characters and how to enable BBCode there (for example: http://www.icyphoenix.com/search.php?search_keywords=ownage).
Now you see standard 100 characters I presume on every post. What I would like to create, is that if someone searches for a word, they can see the whole post including images and videos, making it a hopefully a populair weblog addition.
You need to change the link in the block for that.
OPEN blocks/blocks_imp_wordgraph.php
                'WORD_SEARCH_URL' => append_sid(SEARCH_MG . '?search_keywords=' . urlencode($word)),
                'WORD_SEARCH_URL' => append_sid(SEARCH_MG . '?search_keywords=' . urlencode($word) . '&return_chars=10000'),
Exactly what I wanted and needed! Thank you very much!!!
Works perfect, YEAH!
Post Re: [Solved] Wordgraph/ Tag Cloud
thanks for the post... great little addition..
