Post Replacing/Adding Borders
Don´t now if this thing is going to work.
If you look at the images here  i whant some images on the place there it is red lines.
No border just 2 images.(repeat)
And the second thing is how can i put the text User a little more down.
Big thanks
Jogge
Filesize: 20.87 KB
Viewed: 130 Time(s)
Edited by Chaotic, Wed 27 May, 2009 07:00: Edited topic title to be more specific of issue. :)
JoggeSend private message
Post Re: Some Help Please
You mean you want to be able to do something like this and have graphics all the way around ?
There are some other examples here, and there is also "Style Demo" (That I'm woking on) in the header that you can switch themes with.
h**p://lopalong.com/forum/index.php
YES, this is what i meen.
You don´t have some info that i can check out about this?
PS. It seems hard to reg. on your side, i get this
Sorry, but your Anti-Spam answer is NOT correct.
Please try registering again.
Jogge
have a look at the theme floreal it does what you want..
Your questions have some difficulties because you don't say if it's v27* or RC* etc.
If it's v27* then forget it because it will never be compatible with any other v27* styles because the user would have to disable borders, background and sub-headers for the blocks in the CMS. And that makes it quite useless.
If it's RC*, then as DrWHO suggests, Floreal will give you some ideas - It may not be totally suitable for what you are trying to do, but ideas nevertheless.
RC*
The two main components of altering the blocks are the style.cfg where you would add new global vars and markup etc, and the cms_block_inc_wrapper.tpl (copied to "Your" style) where you would implement those changes.
Re The spam answer:
I've probably changed / updated some .tpl files and haven't added the MOD script. I had also forgotten to disable registrations again after doing some testing.
Thanks both Lopalong and DWho, i shall make a test of this.
If i succedded i will bring a skin(or more) to this community
Jogge
Jogge,
I haven't made any themes with full wrappers that are basically using the default IP style. And until the final stable release of IP v? what I have done is possibly of no use to you. After then, I will more than likely make a couple of different "Default" styles with full wrappers etc.
That's why I didn't offer them to you.
No Problem Lopalong.
I have test to make some with images all around and i have made that
with a code from another person.
Think i must ask this person if it OK to publish the skin when i am finish with it.
Have some problem with some tables.
Thanks anyway.
Jogge
