Post [SOLVED] Running 2 Icy Phoenix Boards On One Domain Login Problems.
Hello all,
I am having trouble running to boards on one domain. I keep being logged out by either board. If I log into one, then the other is logged out.
Could this be a cookie issue? I have tried changing some cookie settings but as stated in the ACP I then have logging in issues.
If anybody can help this would be great,
thanks in advance,
Morto.
Morto - View user's profileSend private message
Post Re: Running 2 Icy Phoenix Boards On One Domain Problems.
I only have this problem when using local host on my own computer
i would go into ACP/configuration/server and leave one site with the cookies set as below
 27_05_2009_09_46_51
and then change the cookies on the other site to something completely different..
then clear both caches on both sites and clear cookies in all the browsers you use...
I hope that helps
DWho - View user's profileSend private messageVisit poster's websitePersonal Gallery
DWho wrote: [View Post]
like what "aha_cookies"  ? or ?
i m faceing also  this in local
Limun - View user's profileSend private messageVisit poster's websitePersonal Gallery
like urdomain_ip_cookies ^_^ (try to not put too char :O)
Informpro - View user's profileSend private message
yep that will work
yep that will work
And it did thanks for the help guys, also I only needed to rename the cookie and refresh the caches!
Fantastic response from IP team once again   ,
thanks,
Morto.
Post Re: [SOLVED] Running 2 Icy Phoenix Boards On One Domain Login Problems.
