Post Problem With Installation
hi
i have download your icy phönix package. I follow the instructions in the german read me and upload all to my webspace (funpic.de). Then i change all chmods and get a okay from the install page. After this i klick on install on the ground of the install page...then an error message appear...
"Forbidden You don't have permission to access /ip_root/install/install.php on this server." "Apache/2.2.11 (Unix) mod_perl/2.0.4 Perl/v5.10.0 Server at xabot3.xa.funpic.de Port 80".
edit: i alrady have a forum from phpbb3 with your skin black pearl (it is very nice) and in this forum are a lot of threeds. is there a possibility to intigreate the threeds, member, and the rigth management into your produkt? because it was a lot of work and i dont want to lose it. otherwise i want to have the hp arround my forum how it is in your projekt   because it is very nice
sorry for my bad englisch
thanks for help
mfg
xabot
Xabot - View user's profileSend private message
Post Re: Problem With Installation
Are you sure you have upload all files to http://xabot3.xa.funpic.de/ip_root/ ?
i have upload the whole ip_root folder
edit: with a lot work i have made it   now it works
thanks for help
Do you whant to tell us, what the problem was?
And how you fix it.
