Re: ( Possible BUG) Calendar Does´nt Show In Forum
Changed Lang to english
Emptied cache
Checked options in
ACP
All folders are there without any changes.
still nothing.
Calendar block work´s on Index but the calendar row in forum still does´nt apear.
EDIT:
Thats definitly an link Problem.
If you click on calendar in profil it should say
HOME-PROFILE-CALENDAR but it does´nt
Now another thing :
I went to : Includes/mod_settings/mod_calendar.php
and changed this
'show_calendar_box_index' => array(
'lang_key' => 'Calendar_block_display',
'type' => 'LIST_RADIO',
'default' => 'Yes',
'values' => $list_yes_no,
'calendar_display_open' => array(
'lang_key' => 'Calendar_display_open',
'default' => 'Yes',
'user' => 'user_calendar_display_open',
Now it seems to work.
But not like it should.
In Profil:
in calendar theres zip options.
If you click on forum link below calendar link, there turns up the calendar option.
so something is definitly wrong there
