Post Create A Column (like The Left Side On This Site)
Hi there!
Currently i do have a forum with black pearl style, and i do have a column on the left side like your site. I got some images, and the partners banners on this side, but i dont have them with no column (its ugly =S). -> www.discutivel.comuf.com
My goal its to have the content that i already have ATM, in a clumn just like in this site:
http://img32.imageshack.us/img32/7590/column.jpg
or this:
http://img190.imageshack.us/img190/1754/column2.jpg
Best regards =D
unknown2 - View user's profileSend private message
Post Re: Create A Column (like The Left Side On This Site)
can somebody move this to PHPBB3 mods and templates PLS
Icy-Mods.com ( IP 2.0 RC-1)
moved to phpBB 3 MODS And Styles
Play Games at GamesCampus!
As I said in the other topic you need to wrap the content in a table.
Try this.
OPEN overall_header.html
<div id="wrapcentre">
<td width="180" align="left" valign="middle">
<div><div class="tbl-h-l"><div class="tbl-h-r"><div class="tbl-h-c"><div class="tbl-title">{L_MEMBERLIST}</div></div></div></div>
<table class="tablebg" width="100%" cellpadding="0" cellspacing="0">
<tr><th>Sponsor</th></tr>
<tr><td class="row1">Sponsor</th></tr>
</table>
<div class="tbl-f-l"><div class="tbl-f-r"><div class="tbl-f-c">&nbsp;</div></div></div></div>
</td>
<td align="center" valign="middle">
OPEN overall_footer.html
    <!-- IF not S_IS_BOT -->{RUN_CRON_TASK}<!-- ENDIF -->
</td>
<td width="180" align="right" valign="middle">
</table>
</td>
</table>
Let me know...
I think your las post, its the awnser to this topic: http://www.icyphoenix.com/viewtopic.php?p=41753#p41753
The question im mention in this topic, its not the same. I was not spamming =S
In the other topic i was trying to add a Column in the right side. (like the column i currently have in the left side of my forum.
Here i was trying to create just the box higlighted in red -> http://img32.imageshack.us/img32/7590/column.jpg
Anyway, i have tryed the last code that you posted, and i think it will soon solve the 2 issues that i was mentioned in diferent topics:
1st: the creation of a column on the right side
2nd: the creation of a box for the sponsors/partners
After some experiences of copy/paste your code, varying the lines where i post them, i finally get somthing wich is similar of my ideal of forum!
a) http://img505.imageshack.us/img505/3914/50612197.jpg
b) http://img266.imageshack.us/img266/2581/centerb.jpg
I only need that the boxes come up (as explained in the A pic), and center all the content shown inside the boxes (as explained in the B pic).
I only ask you for check my forum to see the code (discutivel.comuf.com), and tell me what where my mistakes.
i thank you in advance, for all your patience helping me out on this issues!
Try with:
<td valign="top">
It worked =D
Now, how i make the banners, ads and etc, be centered on the tables?
And how do i remove this space (http://img248.imageshack.us/img248/7500/spacez.jpg) on the table??
Best regards
Well you should at least first try on your own...
These are the basics of HTML and CSS, if you want to manage a website you should at least learn the basics.
Just to be clear, it is not that I don't want to help... we give hints and tips but the user must at least learn something...
Y, i understand that
I use the <center></center> and it worked out fine =)
tks!
can i mark this as solved..?
Some part is solved, cause i already got the columns that i wish. But..
With this solution another problem came up. Now the content of the mid table of the forum its not adjusted to the size of a 1024x760 screen =S
Can you help me out to solve this problem ??
please stop sending me PM unknown2.... thank you!
roflolol.
Maybe u should do that 2! cause i told u to stop and ur continuing...
Even if u send another one, or post anything here, i will not awnser again.
Damn kids...
? hmmmzzz
I hope there is not a problem here...
Also if you got your preferences you can turn off pms from other users...
HideSimilar Topics
