Post Link Clicking In The Banner (top_header.png) Milky_Way's Style
Some days ago I posted some problems that I cought fix, the result: fifa-gaming.com.ar.
I would like to redirect to the portal when I click in the header banner (top_header.png)
Probably I have to add some command at the stylesheet.css
#top_logo{
    border-width: 0px 0px 0px 0px;
    margin: 0px 0px 0px 0px;
    padding: 0px 0px 0px 0px;
    background: url('./images/top_header.png') repeat;
    height: 150px;
But I don't know that command and it would be nice if you give me it.
I just want to redirect to the portal (fifa-gaming.com.ar URL) when I click in the banner, I hope you understand what I'm talking about.
Thank you very much!
BlancoLandaSend private message
Post Re: Link Clicking In The Banner (top_header.png) Milky_Way's Style
up´s
look´s like you´ve removed sitelogo_small totaly.
sitelogo_small was linking back to index automaticly.
why don´t you create a white backround or transparent.
then you create your logo as sitelogo_small with full size of header and adjust it to your header.
the original code link´s you back
Edit
sry i did´nt see the PhpBB mod issue.
What i said before is for Icy
can you post your overall_header file PLs.
Thank you for the fast reply!
Overall_header:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="{S_CONTENT_DIRECTION}" lang="{S_USER_LANG}" xml:lang="{S_USER_LANG}">
<head>
<!-- INCLUDE _mg_config.html -->
<meta http-equiv="content-type" content="text/html; charset={S_CONTENT_ENCODING}" />
<meta http-equiv="content-language" content="{S_USER_LANG}" />
<meta http-equiv="content-style-type" content="text/css" />
<meta http-equiv="imagetoolbar" content="no" />
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
<meta name="resource-type" content="document" />
<meta name="distribution" content="global" />
<meta name="copyright" content="2000, 2002, 2005, 2007 phpBB Group" />
<meta name="keywords" content="" />
<meta name="description" content="" />
{META}
<title>{SITENAME} &bull; <!-- IF S_IN_MCP -->{L_MCP} &bull; <!-- ELSEIF S_IN_UCP -->{L_UCP} &bull; <!-- ENDIF -->{PAGE_TITLE}</title>
<link rel="stylesheet" href="{T_STYLESHEET_LINK}" type="text/css" />
<script type="text/javascript" src="{T_TEMPLATE_PATH}/scripts.js"></script>
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
    if ({S_NEW_PM})
        popup('{UA_POPUP_PM}', 400, 225, '_phpbbprivmsg');
<!-- ENDIF -->
function popup(url, width, height, name)
    if (!name)
        name = '_popup';
    window.open(url.replace(/&amp;/g, '&'), name, 'height=' + height + ',resizable=yes,scrollbars=yes,width=' + width);
    return false;
function jumpto()
    var page = prompt('{LA_JUMP_PAGE}:', '{ON_PAGE}');
    var per_page = '{PER_PAGE}';
    var base_url = '{A_BASE_URL}';
    if (page !== null && !isNaN(page) && page == Math.floor(page) && page > 0)
        if (base_url.indexOf('?') == -1)
            document.location.href = base_url + '?start=' + ((page - 1) * per_page);
        else
            document.location.href = base_url.replace(/&amp;/g, '&') + '&start=' + ((page - 1) * per_page);
* Find a member
function find_username(url)
    popup(url, 760, 570, '_usersearch');
    return false;
* Mark/unmark checklist
* id = ID of parent container, name = name prefix, state = state [true/false]
function marklist(id, name, state)
    var parent = document.getElementById(id);
    if (!parent)
        eval('parent = document.' + id);
    if (!parent)
        return;
    var rb = parent.getElementsByTagName('input');
    for (var r = 0; r < rb.length; r++)
        if (rb[r].name.substr(0, name.length) == name)
            rb[r].checked = state;
<!-- IF ._file -->
    * Play quicktime file by determining it's width/height
    * from the displayed rectangle area
    * Only defined if there is a file block present.
    function play_qt_file(obj)
        var rectangle = obj.GetRectangle();
        if (rectangle)
            rectangle = rectangle.split(',')
            var x1 = parseInt(rectangle[0]);
            var x2 = parseInt(rectangle[2]);
            var y1 = parseInt(rectangle[1]);
            var y2 = parseInt(rectangle[3]);
            var width = (x1 < 0) ? (x1 * -1) + x2 : x2 - x1;
            var height = (y1 < 0) ? (y1 * -1) + y2 : y2 - y1;
        else
            var width = 200;
            var height = 0;
        obj.width = width;
        obj.height = height + 16;
        obj.SetControllerVisible(true);
        obj.Play();
<!-- ENDIF -->
</script>
<!--[if lt IE 7]>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/pngfix.js"></script>
<![endif]-->
</head>
<body class="{S_CONTENT_DIRECTION}">
<a name="top"></a>
<div style="width:{$MG_GLOBAL_WIDTH};clear:both;margin: 0 auto;">
<table width="100%" align="center" cellspacing="0" cellpadding="0" border="0">
        <td class="leftshadow" width="9" valign="top"><img src="{T_THEME_PATH}/images/spacer.gif" alt="" width="9" height="1" /></td>
        <td class="np-body" width="100%" valign="top">
<div id="top_logo">
<td height="150" align="left" valign="middle">
<a href="{U_INDEX}">{SITE_LOGO_IMG}</a></td>
<td align="center" valign="middle"><h1>{SITENAME}</h1><span class="gen">{SITE_DESCRIPTION}</span></td>
<td align="right" valign="top">&nbsp;</td>
</table>
<!-- INCLUDE menu_block.html -->
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --><span style="color:#CC3333;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
<div id="wrapcentre">
<!-- IF S_USER_PM_POPUP and S_NEW_PM -->
<div style="margin-top:50px;margin-bottom:50px;text-align:center;clear:both;"><div class="popuppm-new"><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a></div></div>
<!-- ENDIF -->
I also will upload the file in a .rar file if you want
overall_header.rar
Filename: overall_header.rar
Filesize: 2.1 KB
Downloaded: 248 Time(s)
try this.
tell me what happens.
overall_header.rar
Filesize: 2.11 KB
Downloaded: 300 Time(s)
Anything happens, it seems that doesn't work.
I tried purging the caché of the style and purging the cache of the ACP.
post the file you´ve located this code please
  1. #top_logo{
  2.     border-width: 0px 0px 0px 0px;
  3.     margin: 0px 0px 0px 0px;
  4.     padding: 0px 0px 0px 0px;
  5.     background: url('./images/top_header.png') repeat;
  6.     height: 150px;
and the original one aswell. without editing if you still got it
Try this:
Find:
Replace with:
<a href="./portal.php"><img src="./styles/milky_way/theme/images/top_header.png" alt="" title="" height="150" width="960"></a></td>
CSS:
Replace the #top_logo block with this.
#top_logo{
    background-color: #c0c0c0;
    height: 150px;
You WILL have to resize top_header.png to about 960px wide to fit the header and this -> height="150" width="960" to whatever you end up with.
That´s what i´ve been thinking about, LOPA.
But since i haven´t got the files, I wanted him to post them so i can have a look.
Because it look´s to me like he deleted the logo image and put his image in the backround.
that´s why the link does´nt work.
Well in my thinking
You already told him what to do here:
spydie wrote:
why don´t you create a white background or transparent.
But obviously he doesn't understand what needs to be done and where to do it.
Lopalong wrote: [View Post]
Try this:
Find:
Replace with:
CSS:
#top_logo{
    height: 150px;
Weird, I did those changes, at the CSS and at the overall_header.html, but I announced that in overall_header.html there isn't exactly:
There is:
<a href="{FULL_SITE_PATH}{U_INDEX}">{SITE_LOGO_IMG}</a></td>
I tried remplacing that and remplacing what you written for the CSS and the image/url does not appear:
fifagaming.th
Now I will re-upload the original overall_header.html for fix again the banner (but it hasn't got the link)
EDIT: I re-uploaded the original overall_header.html and nothing happend, but the banner reappeared when I re-uploaded the old stylesheet.
EDIT 2: uploading the old stylesheet and the new html worked, now I just have to edit the banner so it has a nice view.
Thank you very much for your help.
  1. <a href="{FULL_SITE_PATH}{U_INDEX}">{SITE_LOGO_IMG}</a></td>
that was the change i tried
I know this topic is old but I wanted to post the answer to this because it's so easy and others will finally have an answer to this question.
All you need to do is look in Overall_header and find the 'div' tag that your banner resides in. In this guy's case his banner lies in the "top_logo" div tag.
Once you find the div then just place a simple <a href="h**p://site.com/forum/portal.php"> above the <div id="top_logo"> and then below the </div> you would place </a> and that's it LOL.
Hope this helps everyone.
jdeezySend private message
This problem has been solved and the site is died ...
