Post KnekZ Dark For 1.3
Hello everyone!
Here is my dark template which is based on my previous template using some of DWho's (Thank you for your permission   ) images for Apollo.
Please report any bugs and feel free to make suggestions
Enjoy!
 screenshot_1_1248790611_118195  screenshot_2_1248790633_683806  screenshot_3_1248790653_527777
Install instructions
knekz.zip
Description: KnekZ Blue and Dark with many fixes. Let's say...0.4, maybe 1.4?
Filename: knekz.zip
Filesize: 883.11 KB
Downloaded: 263 Time(s)
KnekZ
* html body {display:none;}
elpulgas - View user's profileSend private message
Thanks for the useful Topic elpulgas:
Limun (28 July), Mighty Gorgon (07 August), rixard (06 October), Man Of Darkness (23 June)
Post Re: KnekZ Dark For 1.3
thanks
nice one also...
i will try it
Limun - View user's profileSend private messageView user's personal gallery
elpulgas wrote: [View Post]
Hello everyone!
Warning: If you installed KnekZ Blue replace all files (yes, images too) or it'll be damaged.
So why dont you use another folder for that theme, so it does´nt come in conflict with KnekzBlue
Icy-Mods.com ( IP 2.0 RC-1)
spydie wrote: [View Post]
Hello everyone!
Well because they are the same in structure so there's no need for that as more files = slower most of the times. I just said that because I updated many files from the blue too so the last download I posted is not really the newest
I forgot about the screenshots. Going to post them now
I also forgot this image
 arrow_up_rounded
Upload it to templates/knekz/images/dark/buttons/  and replace the old white one
KnekZ
The style is really nice... I like the way you design.
KnekZ
maybe you can right some docs on graphic design and css... just some hints and tips... so the ovice users ca nhave a go at making bits and pieces... just a thought...
DWho wrote: [View Post]
You mean "write"?
I think that would be nice, yes. Although I'm not really a very good writer but I can dive it a try later   .
But I think the best way to learn is to practice on your own. For example by using firebug or webdeveloper (addons for firefox) to edit the CSS of other pages, not just your own. Always look at the source code of sites you like. Not copy, but just have a look at the way others make things. Sometimes you just need another approach and you also can learn good tricks by doing that.
KnekZ
This style is amazing.  I'm thinking of using it on one of my websites!
Great work man!
Chaotic - View user's profileSend private messageVisit poster's websiteView user's personal gallery
Chaotic wrote: [View Post]
Great work man!
But keep in mind the original images come from DWho. And I think you can't consider this a style yet. It's more like a sketch because there is still much CSS to edit like code on posts or calendar and so on. They still have light backgrounds
KnekZ
Great work and good tips too!
I've got a favorite style from phpbb 3.05 that would be excellent for porting to IP 1.3. It's similar to you and Dr. Who's. The author would have to be contacted.
The style is here: http://www.thegtsaga.net/portal/
My main IP 1.3 site
My IP 1.3 styles test site
gearhead - View user's profileSend private messageVisit poster's websiteView user's personal gallery
I have noticed that links on top are dark text on dark background when you hover the mouse on them... maybe a ligher text should better fit... just a suggestion though.
Yes, i have to fix that. Maybe just change the background image to a bright color on hover instead of using transparency.
KnekZ
Pulgas,,, you are from my country!! colombia!!!
I need some help, i canot install any theme!°!!!!!!!!
Light - View user's profileSend private message
Light wrote: [View Post]
Yea cool. Although I'm not there anymore jaja. I'll PM you.
KnekZ
