probably you all noticed from the question that i'm not familiar with ICY, but i hope i can get better in time.
My first question is how to create classes and use them when i post a message. I will describe an exemple:
[cell class=spoiler bgcolor=#AACCEE bordercolor=#224488 width=320 borderwidth=1][font=Trebuchet MS][size=14][color=seagreen]Name[/color][/size]
[cell class=spoiler bgcolor=#CCDDEE bordercolor=#446688 borderwidth=1 width=300 padding=1 margin=5][color=red]1.
2.
3. [/color]
[/cell][cell class=spoiler bgcolor=#CCDDEE bordercolor=#446688 borderwidth=1 width=300 padding=1 margin=5][color=blue]4. [/color]
[/cell][cell class=spoiler bgcolor=#CCDDEE bordercolor=#446688 borderwidth=1 width=300 padding=1 margin=5][color=green]5.
6. [/color][color=darkred](10-3)[/color]
[/cell][/font][/cell]
2.
3. [/color]
as you see above i used the class called spoiler for the cell and that imposed some properties for the cell. Now, in the same way i want to define a class that will make my cell look exactly as above if i writte one under another in between the tags for cell the followings:
name
1.
2.
3.
4.
5.
I hope you understood and can help me. Thanks.
In the Boxes
/dev/www/public/icy-phoenix
