odelot
 BIG PROBLEM WITH NEW INSTALATION
After installing newly I have this mistake in unloads. I don`t to do. ¿What`s the problem? I don´t understand
Mi futura página:www.eltricornio.es
Host de pago
Icy Phoenix:1.3.0.53
#1 Fri 07 Aug, 2009 21:03 |
spydie
 Re: BIG PROBLEM WITH NEW INSTALATION
you image is a bit small.
can´t see anything but for me your page loads fine
____________ Out of Order
#2 Fri 07 Aug, 2009 21:06 |
DWho
goto the download page Spydie you wil see the error there... though it does look like a server problem of some kind... maybe someone who know will be able to help..
#3 Fri 07 Aug, 2009 21:13 |
spydie
Site is dissabled
#4 Fri 07 Aug, 2009 22:35 |
odelot
This is the problem
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of fsockopen(). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /var/www/vhost/eltricornio.es/home/html/includes/pafiledb/functions.php on line 329
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /var/www/vhost/eltricornio.es/home/html/includes/pafiledb/functions_pafiledb.php on line 301
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /var/www/vhost/eltricornio.es/home/html/includes/pafiledb/functions_pafiledb.php on line 377
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /var/www/vhost/eltricornio.es/home/html/includes/pafiledb/functions_pafiledb.php on line 403
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /var/www/vhost/eltricornio.es/home/html/includes/pafiledb/functions_pafiledb.php on line 1527
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1189: Cannot modify header information - headers already sent by (output started at /includes/pafiledb/functions.php:329)
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1191: Cannot modify header information - headers already sent by (output started at /includes/pafiledb/functions.php:329)
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1192: Cannot modify header information - headers already sent by (output started at /includes/pafiledb/functions.php:329)
#5 Fri 07 Aug, 2009 22:52 |
gearhead
I had a very similar problem with my upgrade from 1.2 to 1.3.
I didn't have as many errors, but most of my pages wouldn't load. I think I already had database errors, or the upgrade would have worked perfectly.
#6 Sat 08 Aug, 2009 04:49 |
odelot
Free hosting with no one having problems. I guess then that will be hosting
#7 Sat 08 Aug, 2009 16:28 |
spydie
The most off FreeHosters wan´t allow some ICY functions on there servers.
is your ´s a paid for server ??
or free hosting site?
#8 Sat 08 Aug, 2009 16:33 |
odelot
The problem I have with server payment
#9 Sat 08 Aug, 2009 17:21 |
Inactive User
It's a php upgrade thing and if you google for it you should find all the reasons why.
In the meantime it tells you how to fix it here:
No doubt that this will have to be addressed by MG, but in the short term - you need to patch it.
#10 Sat 08 Aug, 2009 23:46 |
odelot
.[/quote]
But I do not know how to fix it
#11 Sat 08 Aug, 2009 23:57 |
spydie
What Lopalong want´s to say is , that you´ve got to enable that option in your PHP.ini file if you got access to it on your server
#12 Sun 09 Aug, 2009 00:40 |
gearhead
That's got to be the reason. I don't have any real control over php.ini. My host told me that every month they do a host wide clean sweep of any changes made to the php.ini.
They say it's a security issue. I wish I would have remembered that before I paid them for another year. Ah, well, my site is running great after a new install.
#13 Sun 09 Aug, 2009 01:24 |
Inactive User
If you have a php.ini file in the public root at your server, then add the code below to it:
; Whether to enable the ability to force arguments to be passed by reference
; at function call time. This method is deprecated and is likely to be
; unsupported in future versions of PHP/Zend. The encouraged method of
; specifying which arguments should be passed by reference is in the function
; declaration. You're encouraged to try and turn this option Off and make
; sure your scripts work properly with it in order to ensure they will work
; with future versions of the language (you will receive a warning each time
; you use this feature, and the argument will be passed by value instead of by
; reference).
allow_call_time_pass_reference = true
If you don't have a php.ini file - Then create one in the root of your public folder and add the code to it and CHMOD to 705.
#14 Sun 09 Aug, 2009 09:22 |
odelot
I created the file ini.php and I have introduced this :
<?php
* Whether to enable the ability to force arguments to be passed by reference
; reference).
the problem persists
#15 Sun 09 Aug, 2009 13:03 |
