Post DEBUG - Deprecated: Function Set_magic_quotes_runtime() Is Deprecated
FIX: Deprecated: Function set_magic_quotes_runtime() is deprecated
OPEN: common.php
SEARCH:
    set_magic_quotes_runtime(0); // Disable magic_quotes_runtime
    if (@ini_get('register_globals') == '1' || strtolower(@ini_get('register_globals')) == 'on' || !function_exists('ini_get'))
        deregister_globals();
    define('STRIP', (get_magic_quotes_gpc()) ? true : false);
REPLACE WITH:
    if(version_compare(PHP_VERSION, '5.3.0', '<'))
Host Server: Linux (Aruba)
IP Version: 1.3.1.54 Modded
IP WebSite: MakingART (Web 2.0)
FedericoBiccheddu - View user's profileSend private messageVisit poster's website
Post Re: [FIX] Deprecated: Function Set_magic_quotes_runtime() Is Deprecated
I think that fix needs an argument against the latest php where it has been deprecated and not the current version.
Something like:
    if(version_compare(PHP_VERSION, '6.0.0-dev', '<'))
Do this > > >
else
Etc, etc...
Something like that.
Did you check the documentation @ php.net to check this?
Mighty Gorgon - View user's profileSend private messageVisit poster's websitePersonal Gallery
I found this: Bug #47857: Deprecated set_magic_quotes_runtime
thanks for that  iknow so one else was having this problem on local i will direct them to this post..
DWho - View user's profileSend private messageVisit poster's websitePersonal Gallery
I have to check this...
I will move to Docs in the meantime.
Thanks for sharing.
Post Re: DEBUG - Deprecated: Function Set_magic_quotes_runtime() Is Deprecated
Yep, I can confirm that I just upgraded xampp which has PHP Version 5.3.0 and I got a whole lot of deprecated error messages generated from common.php along with the usual header warning stuff.
Deprecated: Function set_magic_quotes_runtime() is deprecated in I:\xampp\htdocs\ip3\common.php on line 135
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1192: Cannot modify header information - headers already sent by (output started at /common.php:135)
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1198: Cannot modify header information - headers already sent by (output started at /common.php:135)
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1199: Cannot modify header information - headers already sent by (output started at /common.php:135)
or just replace
  1. set_magic_quotes_runtime()
by
  1. @set_magic_quotes_runtime()
(if you have to fix it now ...)
Informpro - View user's profileSend private message
