Page 1 of 3
Goto page 1, 2, 3  Next
Post [SOLVED]Problem With Header Image
Hi i'm new and i'm triing to customize the white pearl theme
now my problem is
when i place a new html global block using the CMS for the header, if the image have the same dim of the table width declared in overall_header.tpl and in style_p_white.css the right shadow of the forum go back the forum body and not remain in his place
HaoAsakura had tried to help me without success
modifing the code but nothing
the link of my website is http://aboliamo.netsons.org
somebody can help me please?
Sorry for my english
MarfoSend private message
Post Re: Problem With Header Image
what i see is that the problem is not only with the header.
the bar on the right is moved behind the blocks of the right hand.
and i don´t think that you got the bar fixed to the backround.
something went totaly wrong with the css file
spydie wrote: [View Post]
this is the complete style_p_white.css code
can you suggest me how to fix??
In your overall header you have:
                <table width="980" align="center" border="0" cellpadding="0" cellspacing="0">
Change it to:
                <table width="100%" align="center" border="0" cellpadding="0" cellspacing="0">
In the overall footer:
Find class="min250" X 2: and remove both of them.
That's a start! that will / should at least stop a lot of things from overlapping.
Thank´s Lopa.
I can only push him more or less in the right direction,
 but you are one of the best in templates,
seeing directly there the problem comes from.
I edit "His" html and .css on line - to see what changes take effect.
Might let you onto this trick one day.
But at the moment - That's only a part of the fix - because I'm going to leave it up to him / her to try to work out the rest of it.
Lopalong wrote: [View Post]
Change it to:
Sorry but I Can't see this line in overall_header i'm using the one in templates/defult directory because in the directory of the template there isn't this file
[/code]
I've take this file like the overall_header in /templates/default like the overall_header and after  that I've removed the 2 class="min250" I've putted it in the same directory
and after that i've erased the cache in the forum and in my browser but it doesn't work
have i made something wrong??
overall_header.rar
Description: Overall_header.tpl in my /templates/default directory
Filename: overall_header.rar
Filesize: 1.82 KB
Downloaded: 283 Time(s)
Lopa, i disagree with you on overall_header and footer.
it look´s to me that the problem comes from CSS.
specialy this line
#global-wrapper {
    width: 980px !important;
    clear: both;
    margin: 0 auto;
I´m not shure, but i´d like to point this out
specialy this line
#global-wrapper {
    clear: both;
    margin: 0 auto;
ok I've commented this part whit /* before width and whit */ after margin:0 auto;
 but now how can i modify the width of my forum???
decomend that again.
try replacing 980 px for 80%
tell me what happens
it works! but if i open my prefered sites on the left the problem return
what prefered site´s ???
for what i can see. it look´s great now. maybe the header image should be a bit bigger.
you can try yourself, playing with the wide of header image
no sorry it doesn't work for now I and HaoAsakura have decide to avoid this problem using the header like now but if I use an header with the dimension like the forum body the problem come again
the trick is to make the image just a little bit smaller than the forum size. so instaed of 980 you put 978 or something like it
ok thanks ^^
but if I use 980 like forum table dim the dim max that i can use is 930
