Tags And Keywordsconversion, icy phoenix, phpbb, porting
Post CONVERSION - How To Convert phpBB 3 Code To Icy Phoenix [NOT VALID FOR IP 2.0]
Hi all,
here is a small guide on how to adapt some phpBB 3 code to Icy Phoenix.
This how to doesn't include all possible code and combination, but it is just a small reference on the core vars and functions you are likely to find on almost every phpBB 3 page.
This guide may also result useful when trying to port phpBB 3 MODs to Icy Phoenix.
I have also added a file that could help you into the converting process, by automatically converting some basic phpBB 3 vars, functions and classes into Icy Phoenix ones. This file will be included in standard package of Icy Phoenix for the benefit of all who want to use it.
How to use the file?
Put it into includes folder and include it where needed:
FIND:
if (!defined('IP_ROOT_PATH')) define('IP_ROOT_PATH', './');
if (!defined('PHP_EXT')) define('PHP_EXT', substr(strrchr(__FILE__, '.'), 1));
include(IP_ROOT_PATH . 'common.' . PHP_EXT);
ADD AFTER:
include(IP_ROOT_PATH . 'includes/functions_phpbb3_to_ip.' . PHP_EXT);
____________________________
CONVERSION GUIDE
Files Header
<?php
* @package phpBB3
* @version $Id: index.php 8987 2008-10-09 14:17:02Z acydburn $
* @copyright (c) 2005 phpBB Group
* @license http://opensource.org/licenses/GPL-license.php GNU Public License
<?php
* @package Icy Phoenix
* @version $Id$
Global Var
<?php
if (!defined('IN_PHPBB'))
    exit;
<?php
if (!defined('IN_ICYPHOENIX'))
    die(
'Hacking attempt');
Global Page Startup
<?php
define
('IN_PHPBB', true);
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
$phpEx = substr(strrchr(__FILE__, '.'), 1);
include(
$phpbb_root_path . 'common.' . $phpEx);
include(
$phpbb_root_path . 'includes/functions_display.' . $phpEx);
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup();
<?php
define
if (!
if (!
include(
$userdata = session_pagestart($user_ip);
init_userprefs($userdata);
// End session management
Language Inclusion
<?php
$user
->add_lang(array('YOUR_LANG_FILE'));
<?php
include(IP_ROOT_PATH . 'language/lang_' . $board_config['default_lang'] . '/YOUR_LANG_FILE.' . PHP_EXT);
Some Vars
<?php
$phpbb_root_path
<?php
IP_ROOT_PATH
<?php
$phpEx
<?php
PHP_EXT
<?php
"{$phpbb_root_path}index.$phpEx"
<?php
IP_ROOT_PATH
. 'index.' . PHP_EXT
FIND (SIMILAR)
<?php
$user
->data['user_id']
REPLACE WITH (SIMILAR)
<?php
$userdata
['user_id']
FIND (SIMILAR)
<?php
$user
->data['is_registered']
<?php
$userdata
['session_logged_in']
FIND (SIMILAR)
<?php
$config
['CONFIG_VAR']
<?php
$board_config
['CONFIG_VAR']
FIND (SIMILAR)
<?php
$user
->lang['LANG_TEXT']
<?php
$lang
['LANG_TEXT']
Page Header
<?php
page_header
($l_title);
<?php
$page_title
= $l_title;
$meta_description = '';
$meta_keywords = '';
include(
IP_ROOT_PATH . 'includes/page_header.' . PHP_EXT);
Page Body
<?php
$template
->set_filenames(array('body' => 'foo_body.html'));
<?php
$template
->set_filenames(array('body' => 'foo_body.tpl'));
$template->pparse('body');
Page Footer
<?php
page_footer
<?php
include(IP_ROOT_PATH . 'includes/page_tail.' . PHP_EXT);
Die Message
Please note that trigger_error has been implemented also in Icy Phoenix so you don't necessarily need to replace this.
<?php
trigger_error
('LANG_VAR_MESSAGE');
<?php
message_die
(GENERAL_MESSAGE, $lang['LANG_VAR_MESSAGE'], $lang['LANG_VAR_TITLE'], __LINE__, __FILE__)
Basic SQL Query
<?php
$result
= $db->sql_query($sql);
<?php
$result
if(!
$result)
message_die(...);
Login
<?php
login_box
("foo.$phpEx?var=my_var", $user->lang['LOGIN_FOO']);
<?php
redirect
(append_sid(LOGIN_MG . '?redirect=foo.' . PHP_EXT . '&var=my_var', true))
AUTH
<?php
if ($auth->acl_get('f_reply', $forum_id))
//do something
<?php
$is_auth
= array();
$is_auth = auth(AUTH_ALL, $forum_id, $userdata, $forum_topic_data);
if(
$is_auth['auth_reply'])
//do something
<?php
if ($auth->acl_get('a_foo'))
<?php
if($userdata['user_level'] == ADMIN)
Dates
<?php
$user
->format_date($your_timestamp);
<?php
create_date_ip
($board_config['default_dateformat'], $your_timestamp, $board_config['board_timezone']);
functions_phpbb3_to_ip.zip
Description: Function to convert some basics phpBB 3 vars, function and classes into Icy Phoenix ones. It is not perfect and / or complete... but it can be useful.
Filename: functions_phpbb3_to_ip.zip
Filesize: 2.51 KB
Downloaded: 698 Time(s)
Edited by Mighty Gorgon, Sat 29 Aug, 2009 09:10: Attachment updated
Post Re: How To Convert PhpBB 3 Code To Icy Phoenix
Big thank´s for this useful Doc. MG
There´s some thing´s i could´nt solve in a mod i´m trying to port,
But with this i think i can solve it.
Thank´s again MG
Edit :
question: what to do with the html-files that use to come with PhpBB3 Mod´s.
Just rename them to tpl or what ?
spydie wrote: [View Post]
yep without having tested thats what  i would do....
thanks MG a very useful topic... will save a lot of problems...
thank´s DWho.
FYI i´ve allready done it and it work´s
thank´s DWho.
cool
Post Re: How To Convert phpBB 3 Code To Icy Phoenix
I've also added a file that you can use to convert some standard phpBB 3 vars, functions or classes... so if you forget to convert something, or don't know how to do that... with this class you may hopefully solve some problems.
If course... it would be better to manually convert what needed... but just in case you don't have the skill...
If someone uses it, please let me know...
thank´s MG . I´ll give this a try, cause i´m still stuck with this countdown date stuff
Edit:
Got to do this because the server want let me post before another 6 hrs.
Hi MG
Gave your little function script a try on my local test enviorment.
something funny happend.
get 5  errors from common file
I took an original PHPBB3 script off the MOD i´m trying to port, just for testing your script.
Put the include in all necesary files, went to my local server, and called the page up .
result was :
Warning: include(IP_ROOT_PATHctracker/engines/ct_security.PHP_EXT) [function.include]: failed to open stream: No such file or directory in H:\wamp\www\ip_1.3\common.php on line 153
Warning: include() [function.include]: Failed opening 'IP_ROOT_PATHctracker/engines/ct_security.PHP_EXT' for inclusion (include_path='.;C:\php5\pear') in H:\wamp\www\ip_1.3\common.php on line 153
Warning: include(IP_ROOT_PATHconfig.PHP_EXT) [function.include]: failed to open stream: No such file or directory in H:\wamp\www\ip_1.3\common.php on line 257
Warning: include() [function.include]: Failed opening 'IP_ROOT_PATHconfig.PHP_EXT' for inclusion (include_path='.;C:\php5\pear') in H:\wamp\www\ip_1.3\common.php on line 257
Warning: Cannot modify header information - headers already sent by (output started at H:\wamp\www\ip_1.3\common.php:153) in H:\wamp\www\ip_1.3\common.php on line 261
i gave that script thingy a try and i get
Parse error: syntax error, unexpected ')' in public_html/forums/functions_phpbb3_to_ip.php on line 242
my problem is that i dont know enough about php to know why...  and because i dont know enough, is why i tried to use it.  (lets just say i know enough to have messed up my forums enough times to know why and how i break things, and can usually fix them)  I am trying to use this to get a phpbb3 mod working, but i will head over to the right forum to ask my questions about that.
glitchiesSend private message
I have updated the attachment... please try again.
spydie, you didn't define the constants in your file... check IP_ROOT_PATH and PHP_EXT.
Post Re: CONVERSION - How To Convert PhpBB 3 Code To Icy Phoenix
outsch
thanks MG
Silly question but isn't replacing the phpbb copyright or any copyright for that matter with your own as this how to guide shows a GPL violation?
sollordSend private message
sollord wrote: [View Post]
you are not replacing the phpbb copyright ... you are making a mod that is ported from phpbb... as phpbb.com "states you can remove our copyright notices form your forum but please do not ask for support..."
though that is totally irrelavant from porting a mod from phpbb to icyphoenix... as all icyphoenix sites have phpbb copyright in the footer on every page..
Post Re: CONVERSION - How To Convert phpBB 3 Code To Icy Phoenix
Please note that I have not removed phpBB copyright which is still printed in the footer, and that is the copyright that should not be removed.
The commented string is only for developmental purpose, and all edits in the header are just performed to have all file corrected identified by the SVN system.
Original phpBB copyright is untouched and is still in page footer where it has to be.
question MG
what to do with this salt thing in PhpBB3 mods?
I´ve tried just deleting that line but that does´nt work like i want it
Do you mean the form salt?
Open a new topic with an example and I'll help there.
