PHP version 5.2.9
MySQL version 5.0.81-community
on my server and while trying to install i get the following error
The used table type doesn't support FULLTEXT indexes
After that i copied the file with the type changed to MyISAM
Then again while trying to install i get this error
An error occurred trying to update the database
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '=MyIsam' at line 1
Tried replacing with
)TYPE=MyISAM;
and
)TYPE = MyISAM;
How do i fix this.
