Post CUSTOMIZATION - Nav-Quick-Links Menu Closed By Default.
Open: /templates/default/nav_quick_links.tpl
Remove: ALL Script and REPLACE with the script below.
Note: If you wish to modify this menu then you MUST NOT mix it with the cookie script and javascript from the default "Open" menu.
Thanks for the useful Topic Lopalong:
novice programmer (09 September), KugeLSichA (12 September), rendimare (19 October)
Post Re: CUSTOMIZATION - Nav-Quick-Links Menu Closed By Default.
Thanks for this Lopalong i will be adding this shortly
