Post [SOLVED] Internet Blank Forum After Upgrading Internet Explorer Cannot Display The Webpage
i have just upgraded to Icy Phoenix 1.3.0.53 ,
i now have blank forum were my data should be, it just says Test category 1
i rember there was file that you had to replace to get you dir structured back for the life of me i cant rember what the file is called.
if any one can help that would be great.
and yes i am useing the right database!
with thanks
kate
darkasylum - View user's profileSend private message
Post Re: Blank Forum After Upgrading
try doing quick settitngs
Icy-Mods.com ( IP 2.0 RC-1)
spydie wrote: [View Post]
spydie, she gets blanks forum datas, not blank page...
Kate, are you sure you've followed the upgrade procedure in the right way?
I think you've done a fresh installation instead an upgrade from previos version, check if the DB contains the whole datas (olders and newers).
~~~ Andrea ~~~
User #379756 on Linux Counter
buldo - View user's profileSend private messageVisit poster's website
i am now stuck? i got to number 16 , i try and run  http://www.dark-asylum.co.uk/forum/install/install.php
also pulled this from the error log on in the install dir?
[11-Oct-2009 04:35:29] PHP Fatal error:  Call to a member function check_mem_limit() on a non-object in /home/ch0pper/public_html/forum/install/common.php on line 42
but it does not work i get error message of
Internet Explorer cannot display the webpage
   What you can try:
    Diagnose Connection Problems
     More information
any ideas?
16.Run install/install.php and complete the update by renaming and moving images (both posted and in album) and replacing all old links in posts: the automated procedure should be able to perform all these actions automatically, just follow the instructions.
http://www.dark-asylum.co.uk/forum/install/database_update.php
Server And Version Information
◦Installed phpBB version :: 2.0.23 » Latest release :: 2.0.23
◦Installed Icy Phoenix version :: 1.3.0.53 » Latest release :: 1.3.0.53
◦Database Type :: mysql4
◦File Writing :: Your server seems to support files creation and editing.
◦Files & Folders Permissions:
any one help still suck on this please?
for "check_mem_limit()", it's an error, it shoud be "@check_mem_limit()"
Try update to patch A ...
Informpro - View user's profileSend private message
i still having problems.!
update to patch A
when i do this still get blank page?
please please please help?
server And Version Information
◦Installed Icy Phoenix version :: 1.3.0.53a » Latest release :: 1.3.0.53a
Spoiler: [ Hide ]
CHMOD 777
../backup ../cache ../cache/forums ../cache/posts ../cache/sql ../cache/topics ../cache/users ../ctracker/logfiles/logfile_attempt_counter.txt ../ctracker/logfiles/logfile_blocklist.txt ../ctracker/logfiles/logfile_debug_mode.txt ../ctracker/logfiles/logfile_malformed_logins.txt ../ctracker/logfiles/logfile_spammer.txt ../ctracker/logfiles/logfile_worms.txt ../downloads ../files ../files/album ../files/album/cache ../files/album/med_cache ../files/album/users ../files/album/wm_cache ../files/posted_images ../files/screenshots ../files/thumbs ../images/avatars ../logs
Your Icy Phoenix is version is up-to-date
Post Re: [SOLVED] Internet Blank Forum After Upgrading Internet Explorer Cannot Display The Webpage
Try clear cache, I was having problem (of this type) because of SQL cache !
