Post Black Pearl - Q&A Captcha Problem
Im using the Black Pearl style for my phpbb3 forum. When trying to use the Q&A captcha technique it does not show the question asked. I have tried re-installing the style several times. I even tried different versions. Does anyone know a fix for this?
Thanks,
        Homieg
Homieg - View user's profileSend private message
Post Re: Black Pearl - Q&A Captcha Problem
can someone move this to PHPBB please
Icy-Mods.com ( IP 2.0 RC-1)
Which templates files are required to be edited by this mod?
You should follow subSilver 2 instructions (if you have them) to edit Black Pearl style.
It is not a mod i have installed. It is part of the phpbb 3.0.6 update.
hi,
i know you stated that you tried different versions but can you confirm you are using black pearl 1.6.0 ?
if not, here's a link to it http://www.icyphoenix.com/viewtopic.php?f=32&t=2659
Yes it is 1.6.0. I have downloaded it and installed it several times from this site and phpbb3styles.net
Can you confirm that in styles/black_pearl/template/ folder you have the following files?
  • captcha_default.html
  • captcha_qa.html
  • captcha_recaptcha.html
yes they are all there.
I have just tested on my local testing environment and it is working fine.
Make sure you have the latest files, cache is empty and the full template is refreshed in ACP.
