Post Width for hole forum by pixel
Could anybody please tell me what I have to change, that the width of the hole forum will be maybe 800px?
I have done some changings but it's only completly working with IE... not in firefox.
By postings or edit I still get 100%
Thanks to all
Post Re: Width For Hole Forum By Pixel
In overall_header.tpl, in your template folder, find:
  1. <body onload="PreloadFlag = true;">
  2. <a name="top"></a>
  3. <table cellspacing="0" width="100%" id="forum">
and change 100% to 800px
Master Sulu - View user's profileSend private message
Maybe u have to change it from posting and editing to.
Master Sulu wrote: [View Post]
Thanks, thats the one I have done...
But I still get the 100% by writing or editing a topic.
Can you help me what to change
check if there is something like that code at posting_body.tpl
Zuker wrote: [View Post]
Yes, but I don't know what to change there... all tables I have change doesn't work
So, if somebody could help me... Thanks a lot.
maybe MG got the answer...
try this
OPEN overall_header.tpl
<div align="center"><table cellspacing="0" width="75%" id="forum"></div>
and the 75% = must try for 800px ........
pepi - View user's profileSend private messageVisit poster's website
hey pepi  and steffen
The only line to change it's
  1. <table cellspacing="0" width="100%" id="forum">
I've test it
If u want to "center" the forum, de div must be closed after closing the table, at overall_footer.tpl, not there.
Before
<a name="bottom"></a>
Post Re: Width for hole forum by pixel
The main table in Aphrodite is this one:
<table id="forum">
You can either change the width in the overall header or in the CSS where #forum is declared.
Unfortunately some pages have so many things that the width is stretched... you should also change the layout or remove some graphics.
I forgot to say that if you specify WIDTH in HTML you don't have to use PX at the end, because it is not W3C compliant:
WRONG: WIDTH="800px"
CORRECT: WIDTH="800"
In the CSS you should always use PX to avoid confusion with PT.
