Post RainbowPearl And AJAX Chat 2.0.0.B8
Hello,
I'm trying to install the mod AJAX chat 2.0.0.B8.
I took the files from subSilver as a template. It even works.
I use the Style Rainbow Pearl in the latest version.
But I think it looks in the index is still not quite so well:
http://www.aan-forum.de/phpbb3_testforum/
Can someone help me?
I suspect that the changes must be made in the chat_body.html. This was at the Mod here for subsilver2.
Thank you.
Regards Piet.
chat_body.html
<!-- IF S_GET_CHAT -->
    <!-- IF S_READ or S_ADD -->
        <!-- BEGIN chatrow -->
            <div id="p{chatrow.MESSAGE_ID}">
                <table class="tablebg" cellpadding="6" cellspacing="0" width="100%">
                    <tr class="row{chatrow.CLASS}">
                        <td>
                            <!-- IF U_ACP or U_MCP --><a href="javascript:void({chatrow.MESSAGE_ID})" title="{L_DELETE_POST}" onclick="delete_post('{chatrow.MESSAGE_ID}')"><img src="{T_IMAGESET_LANG_PATH}/icon_post_delete.gif" /></a> <!-- ENDIF -->
                             <b class="postauthor">{chatrow.USERNAME_FULL}</b> « {chatrow.TIME} » &nbsp; <span class="postbody">{chatrow.MESSAGE}</span>
                        </td>
                </table>
        <!-- END chatrow -->---{LAST_ID}
    <!-- IF S_WHOISONLINE -->---
            <!-- BEGIN whoisrow -->
                <div><img src="{T_IMAGESET_PATH}/{whoisrow.USER_STATUS}.png" class="online_img" /> {whoisrow.USERNAME_FULL}</div>
            <!-- END whoisrow -->---{LAST_TIME}---{DELAY}---{LAST_POST}
        <!-- ENDIF -->
    <!-- ENDIF -->
<!-- ELSE -->
    <!-- IF S_CHAT -->
        <!-- INCLUDE overall_header.html -->
    <!-- ENDIF -->
    var fieldname = 'chat';
    var last_time = 0;
    var xmlHttp = http_object();
    var last_id = {LAST_ID};
    var type = 'receive';
    var post_time = {TIME};
    var read_interval = 15000;
    var interval = setInterval('handle_send("read", last_id);', read_interval);
    function handle_send(mode, f)
        if (xmlHttp.readyState == 4 || xmlHttp.readyState == 0)
            indicator_switch('on');
            type = 'receive';
            param = 'mode=' + mode;
            param += '&last_id=' + last_id;
            param += '&last_time=' + last_time;
            param += '&last_post=' + post_time;
            param += '&read_interval=' + read_interval;
            if (mode == 'add' && document.text.message.value != '')
                type = 'send';
                for(var i = 0; i < f.elements.length; i++)
                    elem = f.elements[i];
                    param += '&' + elem.name + '=' + encodeURIComponent(elem.value);
                document.text.message.value = '';
            else if (mode == 'delete')
                type = 'delete';
                param += '&chat_id=' + f;
            xmlHttp.open("POST", '{FILENAME}', true);
            xmlHttp.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded');
            xmlHttp.onreadystatechange = handle_return;
            xmlHttp.send(param);
    function handle_return()
        if (xmlHttp.readyState == 4)
            if (type != 'delete')
                results = xmlHttp.responseText.split('---');
                if (results[1])
                    if (last_id == 0)
                        document.getElementById(fieldname).innerHTML = results[0];
                    else
                        document.getElementById(fieldname).innerHTML = results[0] + document.getElementById(fieldname).innerHTML;
                    last_id = results[1];
                    if (results[2])
                        document.getElementById('whois_online').innerHTML = results[2];
                        last_time = results[3];
                        if (results[4] != read_interval * 1000)
                            window.clearInterval(interval);
                            read_interval = results[4] * 1000;
                            document.getElementById('update_seconds').innerHTML = results[4];
                        post_time = results[5];
            indicator_switch('off');
    function delete_post(chatid)
        document.getElementById('p' + chatid).style.display = 'none';
        handle_send('delete', chatid);
    function indicator_switch(mode)
        if(document.getElementById("act_indicator"))
            var img = document.getElementById("act_indicator");
            if(img.style.visibility == "hidden" && mode == 'on')
                img.style.visibility = "visible";
            else if (mode == 'off')
                img.style.visibility = "hidden"
    function http_object()
        if (window.XMLHttpRequest)
            return new XMLHttpRequest();
        else if(window.ActiveXObject)
            return new ActiveXObject("Microsoft.XMLHTTP");
        else
            document.getElementById('p_status').innerHTML = 'Status: Cound not create XmlHttpRequest Object.  Consider upgrading your browser.';
    </script>
    <style type="text/css">
        .box
            width: 95%;
            margin-left: auto;
            margin-right: auto;
        .shouts {
            width: 100%;
            height:300px;
            overflow:auto;
        #chat {
            width: 100%;
            text-align:left;
        #message {
            width: 65%;
        #whois_online{
            vertical-align:text-top;
            text-align:left;
        .online_img {
            vertical-align:middle;
        #act_indicator {
            visibility:hidden;
    </style>
    <div class="box">
        <table class="tablebg" cellspacing="1" width="100%">
                    <th align="center" colspan="2">{SITENAME} {L_CHAT}</th>
            <!-- IF S_USER_LOGGED_IN -->
                    <td align="center" class="cat nav" width="85%">
                        <form name="text" id="text" method="post" action="javascript:void(0);" onsubmit="handle_send('add', this)" autocomplete="off">{L_MESSAGE}:
                            <input type="text" tabindex="1" name="message" id="message" class="inputbox" size="28" />
                            <input class="button1" type="submit" name="submit" value="{L_SUBMIT}" />
                        </form>
                    </td>
                    <td align="center" class="cat nav" width="15%">{L_ONLINE_LIST}</td>
            <!-- ENDIF -->
                <td class="row3" style="text-align:left;" height="220">
                    <div class="shouts">
                        <div id="chat">
                                            <td>
                                                    </a>
                                                <!-- ENDIF -->
                                            </td>
                                    </table>
                </td>
                <td class="row1" nowrap="nowrap">
                        <div id="whois_online">
                </td>
                <td class="cat" colspan="2" align="center">
                    {L_DETAILS}
                    <img src="{T_IMAGESET_PATH}/act_indicator.gif" id="act_indicator" />
                    <strong>• {L_UPDATES} <span id="update_seconds">{DELAY}</span> {L_UNIT}</strong>
                </td>
        </table>
    <!-- IF S_CHAT -->
        <!-- INCLUDE overall_footer.html -->
    <!-- ENDIF -->
<!-- ENDIF -->
PietSend private message
