Post Fetchposts.php On Line 92 Error
error with guests in the portal link
This error is not visible to be registered and logged
imagen
ruidodemente - View user's profileSend private message
Post Re: Fetchposts.php On Line 92 Error
Did you update to latest patch files?
Do you have calendar block enabled for guests?
Mighty Gorgon - View user's profileSend private messageVisit poster's websitePersonal Gallery
I'm getting this as well when I use a forum news block on either the 2 column or 3 column layout.
Full error:
Fatal error: Call to undefined method stdClass::parse() in /home/amisharmy/amisharmy.com/fetchposts.php on line 92
Mooshoe - View user's profileSend private message
Please tell me if you also have a calendar block enabled, so I can check if is just a matter of a missing global.
