Re: Forum Page Tag "Forum" Doesn't Want To Change, Why?
Again it seems you are not describing correctly your issues. Please try to be as more detailed as possible when you need support, otherwise we could not be fully helpful.
To check your issue I need to recreate the same situation on a local installation, but honestly I don't have the time to test that, because it is not a bug. It is a customization you need.
I appologize for that because this time is true what you say, but I didn't know the php file name would take care that much, among other things because it's a matter which worked perfectly in the previous installment I had: 0.27c,
BTW I guess I took the renaming solution to avoid the portal site from here and the spanish site, so it could be logic that now you may help on this, with no hurry ofc. Anyway, the guys from the spanish site gave me a doggy solution (editing overall_inc_header and adding a prefix description) which will work until somebody fixed it properly.
BIG_BOSS wrote:
Sarakin,
¿por qué necesitas cambiar el nombre de la página de forum.php a index.php?
Poor Sarakin's translation services
Sarakin, why do you need to change forum.php page's name to index.php?
Because I run Icy for some time, so all indexers (Google, MSN, etc) have now my links like index.php and I guess it's easier to fix this than writing to all of them in order to fix all broken links.
Support Info
Ivory Tower URL: :
http://www.heroesvi-tdm.es/foro/ <- Finally, 100% Updated Icy!
Version: 1.3.0.53b
