Post Fixed Width In All IP
Hello, I have changed logo today, but it width is not 100% , it is fixed, so when anybody who have monitor larger then mine see this 3e62377abfe7
Tell me please how to make forum width fixed in pixels?
Ripley - View user's profileSend private messageVisit poster's website
Post Re: Fixed Width In All IP
You open the file that is in ROOT / templates / your template  / overall_header.tpl
Seeks
  1. <td align="left" height="100%" style="vertical-align: middle">
  2.         <!-- IF GL_BLOCK -->
  3.         <!-- BEGIN ghleft_blocks_row -->{ghleft_blocks_row.OUTPUT}<!-- END ghleft_blocks_row -->
  4.         <!-- ELSE -->
  5.         <div id="logo-img"><a href="{FULL_SITE_PATH}{U_PORTAL}" title="{L_HOME}"><img src="{FULL_SITE_PATH}{SITELOGO}" alt="{L_HOME}" title="{L_HOME}" /></a></div>
  6.         <!-- ENDIF -->
  7.         </td>
Replace with:
  1. <td align="center" height="100%" style="vertical-align: middle">
  4.         <!-- ELSE -->
  6.         <!-- ENDIF -->
  7.         </td>
My_PeSePe - View user's profileSend private messageVisit poster's website
Thank you, but are not they same?
if the code is changed but
Can you try this
OPEN templates/icy_phoenix/style_white_blue.css
#global-wrapper {
    width: 980px !important;
    clear: both;
    margin: 0 auto;
#global-wrapper {
    clear: both;
    margin: 0 auto;
Yes that helped, thank you, I did not see */
But logo did not fit to the right side, in the left everything is ok, but in the right there is something, which I do not know opera dragonfly says it's <div class="sitedes"> , but as I see it's just a text..
you have to make the logo bigger and adjust to the size of your forum
seek in header
<td align="center" height="100%" valign="middle">
        <!-- ELSE -->
        <!-- ENDIF -->
        </td>
replace
                <!-- ELSE -->
        <div id="logo-img"><a href="{FULL_SITE_PATH}{U_PORTAL}" title="{L_HOME}"><img src="{FULL_SITE_PATH}{SITELOGO}" alt="{L_HOME}" title="{L_HOME}" width="100%" height="150px" /></a></div>
        <!-- ENDIF -->
The width is fixed in pixels now.
Logo size is fine, it is something else that prevents    d0aed6f0d92e
It may not be for the logo if the code in the header have more room for normal. I spend the same and were some <td
My_PeSePe wrote: [View Post]
Yes, I think it is somewhere in templates, I have same problem with milky way blue when we were at phpbb, will search tomorrow, thank you
