Post Milky Way Red - Compose PM Problem
Our members can send a PM if clicking on the PM icon in the Memberlist or ViewTopic, but from the PM section in the UCP when clicking on "Compose" the TO field reads "None" with no way to insert a member's username.
I have noticed this on a a couple of templates and do not understand why this happening.
Any help?
BroIgnatius1 - View user's profileSend private message
Post Re: Milky Way Red - Compose PM Problem
are you referring to Icy Phoenix or phpBB 3?
sorry.
This is on phpbb3.
Topic moved to "phpBB 3 MODS And Styles"
It seems really strange, but I will check.
Are you sure you are using latest versions of both phpBB 3 and Milky Way Red?
hi there,
you can actually change this using the " send to"  box and "add to" button if i m not mistaking
