Page 1 of 3
Danielc
 Icy Phoenix Replaces '"' To '\"' In Every Code.
I have a problem with my site.
When i add a code in my page (for example, my Google Analytics code, or the HTML blocks in CMS), Icy Phoenix (i'm not sure if this could be a problem of another thing) adds a backslash \ before every quotation mark ".
For example, i added this in a HTML block:
But, in my page, or when i see the block again in my CMS, this is the code:
<script type=\"text/javascript\">
Do know how can i solve this problem?
Thanks!!
#1 Fri 02 Jul, 2010 19:59 |
Thanks for the useful Topic Danielc: sunwest (23 July) |
TopoMotoV3X
 Re: Icy Phoenix Replaces '"' To '\' In Every Code.
 Link to your WebSite bro, please.
____________ IP Version: 1.3.0.53b
Server: Linux
#2 Fri 02 Jul, 2010 20:34 |
Danielc
http://www.miiconsola.com
A few minutes ago i edited manually the Google Analytics code (in the database) so the page is valid (in W3C), but the problem still happens when i use the ACP to modify this.
Thanks!
#3 Fri 02 Jul, 2010 20:53 |
TopoMotoV3X
it seems that everything is ok, you have this problem a long time? I do not know what it is, it never happened
Server: Linux
#4 Fri 02 Jul, 2010 23:13 |
Danielc
I don't know.. Is there any configuration in PHP that could cause this?
#5 Fri 02 Jul, 2010 23:18 |
TopoMotoV3X
Not that I know, You can check if there are errors on the database and fix it with "Check database" which are in the ACP/DB and Security/Database Maintenance/Check database
Ps: I suggest you do a database backup before making any restore operation.
Server: Linux
#6 Sat 03 Jul, 2010 00:06 |
Danielc
There wasn't errors in my DB. Also I tried to change my Database charset but it doesn't worked. I think that IP encodes the URL's or PHP is doing that. I disabled magic_quotes some time ago, is it causing the problem?
Thanks!
#7 Sat 03 Jul, 2010 01:22 |
TopoMotoV3X
Yes! It could be... You can enable and see if it works? Clean cache after it.
Server: Linux
#8 Sat 03 Jul, 2010 05:39 |
Danielc
Yes, it was. Icy Phoenix requires magic_quotes_sybase to be On. I don't think this is good. It's Deprecated in PHP 5.3.0
Thanks!
EDIT:
If i just enable magic_quotes_sybase it damages my page's style, so i disabled it till it is corrected in Icy Phoenix. I think i must enable all magic_quotes variables, but i want to avoid that.
Thanks!
#9 Sat 03 Jul, 2010 17:48 |
Informpro
Hum, I think you got problems because you site were with magic_quotes.
#10 Sun 04 Jul, 2010 00:12 |
Danielc
So, what can i do?
Thanks for your help!
#11 Sun 04 Jul, 2010 02:29 |
sunwest
Has there ever been a resolution to this problem?
#12 Tue 13 Jul, 2010 14:29 |
sunwest
 Re: Icy Phoenix Replaces '"' To '\"' In Every Code.
Come on! Someone must have a resolution to this problem. Since magic quotes are no longer supported in php, this problem should not be happening.
Surely this must be serious enough for the author of this application to do something to correct it. If there is a fix, we need to know about it.
#13 Mon 19 Jul, 2010 14:52 |
buldo
Just try this [1] and let me know.
[1] http://www.icyphoenix.it/download.php?id=397
____________ ~~~ Andrea ~~~
User #379756 on Linux Counter
#14 Thu 22 Jul, 2010 02:14 |
spydie
@buldo . you need to be registrated to view or download
____________ Driving me and my PC crazy, trying to create some pluggins
Icy-Mods.com ( IP 2.0 RC-1)
#15 Thu 22 Jul, 2010 12:07 |
Page 1 of 3
| Link this topic |
| URL |
| BBCode |
| HTML |
