Post Help on Dice BBCode!
Hi, neighbours and friends...
I'm trying to make a new bbcode for Role Playing Games and whatever a random number generation could be for.
I used to use it for making contests in my web.
I've made this:
open includes/bbcode.php
Find (for instances)
  1.             'fade' => array(
  2.                     'nested' => true,
  3.                     'inurl' => true,
  4.                     'allow_empty' => false,
  5.                     ),
Right after add
  1.             'dice' => array(
  2.                     'nested'    => false,
  3.                     'inurl'        => false,
  5.                     ),
Find
  1. // --- Disable Active Content Switch BEGIN ---
Right before add
  1.         // BBcode dice, by Roland at ka-tet-corp.com. Based upon MOD-dice by >achary Aerogos (tribalgenesis at hotmail.com)
  2.         if($tag === 'dice')
  3.         {
  4.             $Die = $content;
  5.             $Expressions = explode('d', $content);
  6.             if( (isset($Expressions[0])) && (isset($Expressions[1])) )
  7.             {
  8.                 $dice_Rolls = $Expressions[0];
  9.                 $MT_Seed = (double)microtime()*1000000;//intval($Expressions[1]);
  10.             }
  11.             $Die_Count = $Expressions[0];
  12.             $Die_Type = $Expressions[1];
  13.             // Make sure we restore the MT gen to a random state after we are done...
  14.             $Future_Seed = mt_rand();
  15.             mt_srand( $MT_Seed );
  16.
  17.             $Original_Roll_String = '(' . $content . ') <b><span style="color: #AA0000"> Fixed</span></b>';
  18.             $Die_Rolls = explode(' ', trim($dice_Rolls));
  19.             $header = '<b>Sort of roll</b>: ' . $Die_Count . ' dices of ' . $Die_Type . ' sides ' . $Original_Roll_String . '<br /><b>' . $Die_Type . '-Result: </b>';
  20.             $footer = '';
  21.             $Die_Count = intval($Die_Count);
  22.             if( $Die_Count == 0 ) $Die_Count = 1;
  23.             $total = 0;
  24.
  25.             // Loop Limit to prevent 500000d500000 sort of dices due to max. execution time limit
  26.             if($Die_Count <= 200 && $Die_Type <= 100)
  27.             {
  28.                 for( $i = 0; $i < $Die_Count; $i++ )
  29.                 {
  30.                     if( $Die_Type == 100 )
  31.                     {
  32.                         $value1 = (integer)(((double)mt_rand()/(double)mt_getrandmax()) * 10) * 10;
  33.                         $value2 = (integer)(((double)mt_rand()/(double)mt_getrandmax()) * 10);
  34.                         $total = $total + ($value1 + $value2);
  35.                         $footer = ($i != $Die_Count - 1) ? $footer . $value1 . '+' . $value2 . '(' .($value1 + $value2) . '), ' : $footer .  $value1 . '+' . $value2 . '(' . ($value1 + $value2) . ')';
  36.                     }
  37.                     else
  38.                     {
  39.                         $value = (integer)(((double)mt_rand()/(double)mt_getrandmax()) * $Die_Type) + 1;
  40.                         $total = $total + $value;
  41.                         $footer = ($i != $Die_Count - 1) ? $footer . $value . ', ' : $footer . $value . '';
  42.                     }
  43.                 }
  44.             } // Loop limit
  45.             else
  46.             {
  47.                 $total = 0;
  48.                 $footer = 'Too many dices and/or too many sides';
  49.             }
  50.                 // I do b - /b on purpose...  kills out some smilies that crop up.
  51.             if( ($Die_Count > 1))
  52.             {
  53.                 $footer=  $footer . ' (<b>Total =</b> ' . $total . '<b></b>)<BR>';
  54.             }
  55.             else
  56.             {
  57.                 $footer =  $footer . '<BR>';
  58.             }
  59.             $footer = $footer. "";
  60.             $results = $header . $footer;
  61.
  62.             // Restore MT randomness
  63.             mt_srand($Future_Seed);
  64.
  65.             //list($usec,$sec)=explode(" ",microtime());
  66.             mt_srand((double)microtime()*1000000);//$sec * $usec);
  67.
  68.             // Loop to fix randomness problem of results when multiple die rolls are made in a single post - Hades
  69.                 mt_rand();
  70.
  71.             return array(
  72.                 'valid'  => true,
  73.                 'html'  => $results
  74.                 );
  75.         }
To use it, you write:
  1. [dice]xdyy[/dice]
x means number of dices to roll
yy means number of sides of each dice
i.e
  1. [dice]2d10[/dice]
To roll 2 dices of 10 sides.
But now comes the problem.
Because of this line:
  1. $MT_Seed = (double)microtime()*1000000;
Everytime the post is reloaded, the result changes.
I fixed it using precompiled posts, so the message is saved as is and the dices are not rolled every time the post is reloaded.
But I would like to know what should I do to avoid the precompiled posts.
I've tried this
  1. $MT_Seed = $uid;
to use a random number that won't change everytime the post is loaded, but, as $uid is null, I always get the same "Random" number. I mean, If I roll 100 times a dice like 1d10 in 100 different posts, I always get the same number... That's not too random, isn't it?
Any idea is welcome!
Thanks in advance!!
Icy Phoenix Latest 2.0 (working pending)
XusquiSend private messageVisit poster's website
Post Re: Help on Dice BBCode!
I think that the only way to do it is inserting the number in the DB when the post is submitted.
But then you have to modify the posting function...
That would be a solution, but I don't want to mess up with the DB... There must be another solution, as the original mod dosen't make any modification in the DB and works...
If any otherone is interested, I can send him/her the original BBCode to see if we find a solution...
Thnx, MG!!
Attach the mod here... maybe I'll try to do it sooner or later...
Post Re: Help On Dice BBCode!
Looks like there's a very similar post right here.....
h**p://***.icyphoenix.it/viewtopic.php?p=6422#p6422
Does anyone care for it?
Excluding me, of course, since I'm not a programmer.....
Ah, almost forgot: I'm zio_gilmor
IntactoSend private message
Intacto wrote: [View Post]
http://www.icyphoenix.it/viewtopic.php?p=6422#p6422
You are still keeping busy Raphael10 with this... plus I already told you something in the Italian support.
Please do not cross post the same request and be patient.
I finally fix the bug that always give the same result at rolled dices and add an increment value that can be +, -, * or /. I remakes the layout too.
Find
  1. # // BBcode dice, by Roland at ka-tet-corp.com. Based upon MOD-dice by >achary Aerogos (tribalgenesis at otmail.com)
  3.         {
  4.             $Die = $content;
  7.             {
  10.             }
  16.
  20.             $footer = '';
  23.             $total = 0;
  24.
  27.             {
  29.                 {
  31.                     {
  36.                     }
  37.                     else
  38.                     {
  42.                     }
  43.                 }
  44.             } // Loop limit
  45.             else
  46.             {
  47.                 $total = 0;
  49.             }
  52.             {
  54.             }
  55.             else
  56.             {
  58.             }
  61.
  64.
  67.
  69.                 mt_rand();
  70.
  71.             return array(
  74.                 );
  75.         }
Replace
  1. // BBcode dice, by Roland at ka-tet-corp.com. Based upon MOD-dice by >achary Aerogos (tribalgenesis at hotmail.com)fixed by Yuri Menzl Celaschi
  3.         {
  4.             $Die = $content;
  7.            {
  8.               $Dice_Rolls = $Expressions[0];
  9.               $MT_Seed = intval($Expressions[1]);//(double)microtime()*1000000; doesn't work as it causes the rolls to be re-rolled every time the topic/post is re-loaded//
  10.               $Fixed = $Expressions[2];
  11.            }
  12.           else
  13.            {
  14.               return;
  15.            }
  16.             $Die_Count = $Expressions[0];
  17.             $Die_Type = $Expressions[1];
  18.
  19.             /*// Make sure we restore the MT gen to a random state after we are done...
  20.             $Future_Seed = mt_rand();
  21.             mt_srand( $MT_Seed );  */
  22.
  23.             $Original_Roll_String = '<b>(' . $content . ')</b>';
  24.             $Die_Rolls = explode(' ', trim($Dice_Rolls));
  25.
  26.         $Die_Count = substr($Die,0,strpos($Die,'d'));
  27.       $Die_Type = substr($Die,strpos($Die,'d')+1);
  28.       if( strpos($Die_Type, '+') )
  29.       {
  30.          $Method = 1;
  31.          $Modifier = substr($Die_Type,strpos($Die_Type,'+')+1);
  32.          $Die_Type = substr($Die_Type,0,strpos($Die_Type,'+'));
  33.       }
  34.       else if( strpos($Die_Type, '-') )
  35.       {
  36.          $Method = 2;
  37.          $Modifier = substr($Die_Type,strpos($Die_Type,'-')+1);
  38.          $Die_Type = substr($Die_Type,0,strpos($Die_Type,'-'));
  39.       }
  40.       else if( strpos($Die_Type, '*') )
  41.       {
  42.          $Method = 3;
  43.          $Modifier = substr($Die_Type,strpos($Die_Type,'*')+1);
  44.          $Die_Type = substr($Die_Type,0,strpos($Die_Type,'*'));
  45.       }
  46.       else if( strpos($Die_Type, 'x') )
  47.       {
  48.          $Method = 3;
  49.          $Modifier = substr($Die_Type,strpos($Die_Type,'x')+1);
  50.          $Die_Type = substr($Die_Type,0,strpos($Die_Type,'x'));
  51.       }
  52.       else if( strpos($Die_Type, '/') )
  53.       {
  54.          $Method = 4;
  55.          $Modifier = substr($Die_Type,strpos($Die_Type,'/')+1);
  56.          $Die_Type = substr($Die_Type,0,strpos($Die_Type,'/'));
  57.       }
  58.       else
  59.       {
  60.          $Method = 0;
  61.          $Modifier = 0;
  62.       }
  63.
  64.             $header = '<div align=center><b>Dice rolled</b><br>You rolled ' . $Die_Count . ' dices of ' . $Die_Type . ' sides ' . $Original_Roll_String . '<br /><b>Partial Result: </b>';
  65.             $footer = '';
  66.             $Die_Count = intval($Die_Count);
  67.             if( $Die_Count == 0 ) $Die_Count = 1;
  68.             $total = 0;
  69.
  70.             // Loop Limit to prevent 500000d500000 sort of dice due to max. execution time limit
  71.       if($Die_Count <= 200 && $Die_Type <= 100)
  72.       {
  73.          for( $i = 0; $i < $Die_Count; $i++ )
  74.          {
  75.             if( $Die_Type == 100 )
  76.             {
  77.                $value1 = mt_rand(1,9) * 10;
  78.                $value2 = mt_rand(1,10);
  79.                $total = $total + ($value1 + $value2);
  80.                $footer = ($i != $Die_Count - 1) ? $footer . $total . '<b></b> + ' : $footer .  ($value1 + $value2) . '<b></b><br>';
  81.             }
  82.             else
  83.             {
  84.                $value = mt_rand(1,$Die_Type);
  85.                $total = $total + $value;
  86.                $footer = ($i != $Die_Count - 1) ? $footer . $value . ' + ' : $footer . $value . '';
  87.             }
  88.          }
  89.       } // Loop limit
  90.       else
  91.       {
  92.          $total = 0;
  93.          $Modifier = 0;
  94.          $footer = 'Too many dice and/or too many sides';
  95.       }
  96.
  97.       switch( $Method )
  98.       {
  99.       case 1:
  100.          $footer =  $footer . '<span style="color: #00AA00"> + ' . $Modifier . '</span><br>';
  101.          $total = $total + $Modifier;
  102.          break;
  103.       case 2:
  104.          $footer =  $footer . '<span style="color: #AA0000"> - ' . $Modifier . '</span><br>';
  105.          $total = $total - $Modifier;
  106.          break;
  107.       case 3:
  108.          $footer =  $footer . '<span style="color: #00AA00"> * ' . $Modifier . '</span><br>';
  109.          $total = $total * $Modifier;
  110.          break;
  111.       case 4:
  112.          $footer =  $footer . '<span style="color: #AA0000"> / ' . $Modifier . '</span><br>';
  113.          $total = $total / $Modifier;
  114.          break;
  115.       }
  116.       // I do b - /b on purpose...  kills out some smilies that crop up.
  117.       if( ($Die_Count > 1) || ($Method != 0) )
  118.       {
  119.          $footer=  $footer . ' <b>Total =</b> ' . $total . '<b></b><BR>-*-*-';
  120.       }
  121.       else
  122.       {
  123.          $footer =  $footer . '<BR>-*-*-';
  124.       }
  125.       $footer = $footer. "";
  126.       $results = $results . $header . $footer . '</div>';
  127.
  128.     // Restore MT randomness
  129.        mt_srand($Future_Seed);
  130.
  131.
  132.             //list($usec,$sec)=explode(" ",microtime());
  133.             mt_srand((double)microtime()*1000000);//$sec * $usec);
  134.
  135.             // Loop to fix randomness problem of results when multiple die rolls are made in a single post - Hades
  136.                 mt_rand();
  137.
  138.             return array(
  139.                 'valid'  => true,
  140.                 'html'  => $results
  141.                 );
  142.         }
Result of code [dice]2d6+3[/code]
Dice Rolled
You rolled 2 dices of 6 sides (2d6+3)
Partial Result: 6 + 4 + 3
Total: 13
Hope it's help
Yuri MenzlSend private message
Thanks for that.
I've implemented a random number generator in latest RC version, but the value it is not stored in the DB... I will hopefully do it in the future...
You can test it on this site.
This will generate a random number between 1 and 100.
[random=100][/random]
59
Yuri Menzl wrote: [View Post]
WOW! This is a GREAT JOB!!
I just ask you a big help... Would you be so kind by packing it all in a file with some instructions so that I can try to implement the MOD in my site?
I realize I'm asking a lot but it would help me a lot!
Done by myself!!
I repeat: A GREAT JOB!!! THANKS AGAIN!!!
Hey guys!
I'm making a rpg forum with IP plataform and I need the dice bbcode... But, every time the topic page is reloaded the dice results change.
Somebody can help me with this?
Thanks for the help and sorry about the bad english... I'm brazilian.
altamirSend private message
What version of IcyPhoenix are you using?
