Post How To Increase High Of Shoutbox Block In Forum? How To Display More Lines In Shoutbox
I have some questions to the shoutbox
1.
How can I increase the size of the shoutbox block in the forum view? I already increased the high value in shoutbox_block.tpl but this only affects the shoutbox in portal view. In forum view the old, small shoutbox appears.
2.
How can I display more lines in the shoutbox? In ACP value under "AJAX Shoutbox Configuration" is set to 200, but only ~20 shouts are displayed.
Rene - View user's profileSend private message
Thanks for the useful Topic Rene:
Costa (05 September)
Post Re: How To Increase High Of Shoutbox Block In Forum? How To Display More Lines In Shoutbox
For the first question are you talking about AJAX Shoutbox or classic shoutbox?
Regarding the amount of shouts, try to increase the POST PER PAGE in your profile.
I mean the AJAX Shoutbox
Do you have a link for me to check please?
Hey, i've created a temp. admin account for you. User+PW send by PM.
Please check the following: On the portal page (start page) i have a increased shoutbox, the same box should be displayed in the forum but in the forum the box it to small.
Furthermore not all shouts are displayed in the shoutbox. As you can the in ACP, displayed shouts is set to 200.
I have just checked and there is something wrong.
I'll try to fix it.
I'll try to fix it.
Hey, do you know when the fix is ready :)?
