Post Black Pearl - German Buttons
Hello,
i need two Buttons with Text "Bedanken", "Danke entfernen".
I thought there already were some in the forums, cause i downloaded it some months ago, but i don't find them anymore. Would be nice if someone could do this for me. I need them iin the version of "Online" and in the Version of "Create Topic" (Two different Button sizes).
Would be very happy if someone could help me.
DennisenSend private messageSend e-mail to user
Post Re: Black Pearl - German Buttons
are you saying you are still testing phpbb and icy offline after all this time?
I don't understand what you mean ... But if someone can help me, that'll be nice.
I mean i ve had a look at your sites and i can not detect any icy or phpbb black pearl   (only some other black style)
(your older posts here say you were running local tests about two years ago)
Here are all lang buttons for phpBB black pearl.
http://www.icyphoenix.com/styles/co..._id=black_pearl
Look at the end of this site.
Here you can create your own buttons with free text
http://www.icyphoenix.com/customicy_buttons.php
Is there no PSD? In the first package the buttons i need are not included and with the second link i can't even create buttons that are SIMILAR to the original ones
@Joshua: Even I don't know about that time ... No idea what i did at that time.
as far as i know there is a simple psd file included in the package, the buttons that can be created online would have a slightly different font if you choose the best one
i was asking about your board because i don t see a black pearl in use and you are still avoiding to answer this question    so i assume the buttons you want are not to use in black pearl but for the other black style you DO use ?? wich means you ld have to ask permission from MG i guess
Even the color of the buttons in the online generator is not right :/
No, i'm using it for a private phpBB3 forum with black pearl style. IcyPhoenix is too old to use it.
just about anything is possible to adjust there ( you can even make them green ) however i ve used buttons from there in the past and i never noticed black was not black ?¿? could be something wrong with my eyes ofcorse   ..i only know of the font problem
icy still gets many updates BTW
Yeh, i know - but Icy is based on phpBB2 Code - i need phpBB3 Code.
Yep, black is black, but it's very hard to adjust the buttons to get them to be similar to the original ones of Black Pearl. Anyways, i did not use a button but a simple text-link for the thanks feature - looks also good!
This topic can be closed, thank you for helping!
The PSD included with the original release is the same PSD used for original buttons... you only need the right font (which I cannot attach because is not free).
Make sure your monitor is calibrated and you are using the right color profile in PhotoShop (if color profile is not the right one you may experience weird colors).
Make also sure you export them using the "Save for web" feature to get the right settings when exported.
Dennisen,
can you please write the text you wish over the buttons you would like to have.
I can create them for you.
 phpbb3_black_pearl
Well, i would need "Bedanken" and "Bedanken", could you do that for me? Would be nice. I think i need it on the button in first and third row.
I created 3 different buttos, because you can not see the line for the strike ones (by this font).
I used a normal yellow line.
You have to rename the buttons like you wish
Have fun
 blackpearlbuttons_bedanken
bedanken.zip
Description: BlackPearl german BEDANKEN buttons
Filename: bedanken.zip
Filesize: 10.5 KB
Downloaded: 227 Time(s)
Thank you very much, you are great!
