[SOLVED] This Data Is Based On Users Active Over The Past 10 Minutes (change To 5 Mins)??
Hya fellas, were do you change "This data is based on users active over the past 10 minutes" (change to 5 minutes)?
I want the data to be checked over 5 minutes rather than 10 minutes as that's quite a long time, I want it as much real time as possible.
I will keep searching IP to see if its been answered before, but haven't found as yet
The time now is Mon 22 Dec, 2025 18:15 • All times are UTC + 1 Hour
