Post Error 500 After Creating A Category Within A Forum
Hya felles I'm desperate for a fix, I was creating a new subforum via ACP but selected category by accident and submitted, now I'm just getting HTTP 500 Internal Server Error.
I went in to PHPMYADMIN and deleted the new category but still getting the problem and cant access the site.
I did a backup yesterday from ACP but getting duplicate flag errors when I try to upload it to an empty DB
Error
SQL query:
INSERT INTO phpbb_flags (flag_id, flag_name, flag_image) VALUES (1, 'Afghanistan', 'afghanistan.png'),(2, 'AI', 'ai.png'),(3, 'Albania', 'albania.png'),(4, 'Algeria', 'algeria.png'),(5, 'AN', 'an.png'),(6, 'Andorra', 'andorra.png'),(7, 'Antiguabarbuda', 'antiguabarbuda.png'),(8, 'AO', 'ao.png'),(9, 'Argentina', 'argentina.png'),(10, 'Armenia', 'armenia.png'),(11, 'AS', 'as.png'),(12, 'Australia', 'australia.png'),(13, 'Austria', 'austria.png'),(14, 'AW', 'aw.png'),(15, 'AX', 'ax.png'),(16, 'Azerbaijan', 'azerbaijan.png'),(17, 'Bahamas', 'bahamas.png'),(18, 'Bahrain', 'bahrain.png'),(19, 'Bangladesh', 'bangladesh.png'),(20, 'Barbados', 'barbados.png'),(21, 'Belarus', 'belarus.png'),(22, 'Belgium', 'belgium.png'),(23, 'Belize', 'belize.png'),(24, 'Benin', 'benin.png'),(25, 'Bhutan', 'bhutan.png'),(26, 'BM', 'bm.png'),(27, 'Bolivia', 'bolivia.png'),(28, 'Bosnia Herzegovina', 'bosnia_herzegovina.png'),(29, 'Botswana', 'botswana.png'),(30, 'Brazil', 'brazil.png'),(31, 'Brunei', 'brunei.p[...]
MySQL said:
#1062 - Duplicate entry '1' for key 1
Anybody got any ideas on how to sort the error 500?
EDIT:
Sorted the flags now got this sql error, this is driving me up the wall as I need to get sorted ASAP
Error
SQL query:
CREATE TABLE phpbb_force_read_users(
user varchar( 255 ) DEFAULT '' NOT NULL ,
READ int( 1 ) DEFAULT '0' NOT NULL ,
time int( 10 ) DEFAULT '0' NOT NULL );
MySQL said:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'read int(1) DEFAULT '0' NOT NULL,
  time int(10) DEFAULT '0' NOT NULL
)' at line 3
EDIT 2:
Solved the error 500 by using http://yoursite/adm/erc.php and clearing cache, still need to sort the DB issue though
batman - View user's profileSend private message
Post Re: Error 500 After Creating A Category Within A Forum
You can try this... if you want to insert the sql code
CREATE TABLE `phpbb_force_read_users` (
    `user` varchar(255) NOT NULL DEFAULT '',
    `read` int(1) NOT NULL DEFAULT '0',
    `time` int(10) NOT NULL DEFAULT '0'
TheSteffen wrote: [View Post]
Thanks Ill give that a go
batman wrote: [View Post]
If i´m not wrong, I recomended you to use MysqlDumper instead of ACP.
I had this problems once, moving a site to another server, since when, i don´t use Icy Backup utility anymore.
To many errors with doble entrys
Icy-Mods.com ( IP 2.0 RC-1)
