Post Knowledge Base 2 Problems?
The first problem is, in ACP >> Knowledge Base >> Category Manager >> Edit Category or Create Category, I have the article forums setup and choose the forum ID I want for a particular article Category, everything is fine but for some reason the forum ID isn't being updated on submit and keeps reverting to a different forum ID. I.e. when I create a new article no matter what category is chosen it always post in the same forum ID which is nothing to do with the articles.
The second problem is again with the Category.
When viewing a Knowledge Base article and you want a Printable version, you get the error below.
Could not obtain category data
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2
SELECT * FROM phpbb_kb_categories WHERE category_id =
Line : 179
File : functions_kb.php
batman - View user's profileSend private message
Post Re: Knowledge Base 2 Problems?
I have tried re uploading all the KB files but still got the same problems
Can you take a look into you DB?
Do you have this phpbb_kb_categories category???
he must have.
if not it would say, table does´nt exist
Icy-Mods.com ( IP 2.0 RC-1)
Hya fellas, the confusing part is I can create categories, I would have expected this error to also come up whilst creating them.
Just checked my other IP site and this is actually a bug in the latest IP 1.3.0.53b as its also doing it on there which was a clean install.
 23_03_2011_17_16_16
Acording to Bug Tracker this has been fixed?
http://www.icyphoenix.com/bugs.php?mode=view&bug_id=34
Surely somebody knows how IP works to sort these 2 problems? please
could you PM me an test acount with access to ACP, to have a look at the error
Hya spydie I have decided to sack the KB option mate, decided to just use a forums for the articles.
Thanks for the offer to look at it
sorry i cant help you...
i use Forums with KB mode instead of the KB itself...
Play Games at GamesCampus!
Hya KugeLSichA I have now set article forums the same as you now, possibly better than using KB
