Post Only First Post Possible To Read For Guests
Hey,
I don´t know if this is easy possible...
I would like to have a switch, that in one special forum guest can only read the first post.
Maybe with sponsor text above.
Now guest can read the complet topic with all replys.
Does anyone know how to change this or maybe there would be a chnace to insert this in next version of IP
Maybe other users also would like it.
Post Re: Only First Post Possible To Read For Guests
should be possible
i think, i´ve seen something in posting php, or was it viewtopic.php, that had to do with the first post check and post sorting,
adding some code there like :
IF is not first post and Forum ID = Forum ID
display : false;
ElseIf blahblah
This is no actual code,
It´s just an idea
got to play with this idea a bit further, to actual put some usable code here
Icy-Mods.com ( IP 2.0 RC-1)
This should'nt be too complicated.
Informpro - View user's profileSend private message
Thanks spydie and Informpro for your quick answer.
If you have some time you can play with it
Thanks a lot
Hardcoded would be enough for me
(see above)
WOW Informpro, thanks a lot, I will give it a try later.
One Question about that:
  1. if (!$user->data['session_logged_in'])
  2. {
  3.     $sql .= " LIMIT 1";
  4. }
Doesn´t that mean, when user is logged_in then set Limit to 1
Shoudn´t it be, if User logged_out (for guests) then set Limit to 1
Can you please explain to me, that I learn a bit more about php
The "!" means "not".
So "if not logged_id then limit 1".
Tell me if it works !
Hey Informpro,
I tried both versions, but it doesn´t seems to work.
Tested it local with xampp
Do you have something elso for me to test?!?
The real solution :
For every forum
search
  1.      LIMIT " . $start . ", " . $config['posts_per_page'];
Replace with
  1.      LIMIT " . ($user->data['session_logged_in'] ? $start . ", " . $config['posts_per_page'] : 1);
For particular forums only
search
Replace with
  1.      LIMIT " . (!$user->data['session_logged_in'] && ($forum_id == 5 || $forum_id == 6) ? 1 : $start . ", " . $config['posts_per_page']);
Thanks Informpro,
this is working
  1. LIMIT " . (!$user->data['session_logged_in'] and ($forum_id == 1) ? 1 : $start . ", " . $config['posts_per_page']);
But now I get for all topics only the first post.
Not only for $forum_id == 1
Can that be fixed? Thanks
Wow - I'm pretty tired. Just replace "and" with "&&" (and or by ||, if you have). Sorry.
Thanks a lot... it is working fine
Here is the code I used
OPEN viewtopic.php
LIMIT " . (!$user->data['session_logged_in'] && ($forum_id == 1) ? 1 : $start . ", " . $config['posts_per_page']);
Post Re: [SOLVED] Only First Post Possible To Read For Guests
Oh, yes, it should be enough. Glad to help !
Sorry, but I have to ask again...
The chages I made works, but not only for guests.
Even admins can now only see the first post in each topic.
Can that be solved?
I just tried it in my dev version and it works. Try to reverse && parts but ...
