Post Upgrading From PHPBB 2.22
Ok i've followed the directions
# Make a full backup of all files and database (if you don't do a backup, don't dare to ask for support! Backup Rules!)
# Did you backup everything? If you didn't make the backup, please, step back to the previous point.
# Copy your current config.php and keep it in a safe place.
# Check again that your backup is ok and keep it in a safe place.
# Login as administrator.
# Upload and launch install/update_to_xs2.php (i.e. http://www.mysite.com/forum/install/update_to_xs2.php).
and got up to the update part and i got this error:
Critical Error
Could not query CBACK CrackerTracker config information
DEBUG MODE
SQL Error : 1146 Table 'aonserve_main.phpbb_ctrack' doesn't exist
SELECT * FROM phpbb_ctrack
Line : 30
File : ct_ipblocker.php
Someone help?
Looking for webhosting?
Need a excellent host with 24/7 support and free installations for your scripts?
Then pick www.aonservers.com 24/7 in live-time support with tickets/aim/msn/live chat/phone support and more support features.
TheLastLegionSend private message
Post Re: Upgrading From PHPBB 2.22
run this sql query and take a look
  1. CREATE TABLE `phpbb_ctrack` (
  2.   `name` varchar(50) default NULL,
  3.   `value` varchar(100) default NULL
  4. );
nvm mind i fixed that but is there a fix or a like a db update or file updater so i can update 2.21 to 22???
cause there are alot of risks and exploits to 2.21
http://www.icyphoenix.com/viewtopic.php?t=737
z3d0Send private messageVisit poster's website
