Post Black Pearl Problem With Thanks Mod
Hi people,
I'm using Black Pearl 1.6.6, phpbb 3.0.9 and thanks for posts 1.3.1.
I did the installation correctly, without errors and the mod works perfectly in another template (pro silver). In the black pearl I can not see the icon to add/remove thanks, I can only see these icons in messages that have already thanks:
Black Pearl:
Pro Silver:
Something not right in viewtopic of the Black Pearl, what will?
Sorry my bad english.
TJoker666 - View user's profileSend private message
Post Re: Black Pearl Problem With Thanks Mod
Hi TJoker666,
I must admit I don't understand the problem because when I look at those screenshots it looks to me like the thanks button is missing in prosilver and not in black pearl (black pearl looks a bit messed up but it does show the button!)
Did you do the correct edits? ...I mean prosilver edits used for prosilver and subsilver2 edits for black pearl?
Button not appearing in prosilver because screenshot:
I used edits subsilver2 when I install the Black Pearl.
In black pearl the problem is: not appear the icons only appear in messages that have already been thanked other posts do not appear.
you oversaw something probably, or missed one edit in viewtopic, or edited in the wrong place in viewtopic
did you upload the thanks image to blackpearl folder??
Icy-Mods.com ( IP 2.0 RC-1)
There should be an error in the edits of the template files.
Are there instructions for subSilver 2?
