You should do this for yourself... it will be a learning experience for you.
I will try to explain the steps for you.
First step is BACKUP !!!
Create a backup copy of your phpBB and your phpBB database
No you can proceed with the installtion.
Copy all files/directories from the phpbb_root of the FAP package to your to your working phpbb_root
You have done this step already ?
# Upload all files in directory "phpbb_root" with their structure to your phpBB root directory
# Remember to upload all the language files and template files to all your
# language packs and template directories
Edit these files ..... what and where to edit is explained in the FAP install text.
First off .... get you a decent text editor, do not use notepad or FileManager to edit your files.
Context and PSPad are 2 good ones.... Google for either.
These files are not part of the
FAP package, they already exist in your phpbb forum.
If you are using a template other than subSilver you will need to edit the appropiate files in that template, too.
## Files To Edit: (14)
## viewonline.php
## admin/index.php
## includes/bbcode.php
## includes/constants.php
## includes/page_header.php
## includes/usercp_viewprofile.php
## language/lang_english/lang_admin.php
## language/lang_english/lang_main.php
## templates/subSilver/admin/page_header.tpl
## templates/subSilver/bbcode.tpl
## templates/subSilver/overall_header.tpl
## templates/subSilver/profile_view_body.tpl
## templates/subSilver/simple_header.tpl
## templates/subSilver/subSilver.cfg
Set the permissions as instructed
CHMOD means to set the permissions for a file's/directory's use. You can do this through your FTP client.
I can't tell you exactly how to do this, but if you find no CHMOD option look in the Properties option for the file or directory.
CHMOD these directories for Full Album Pack to work correctly.
CHMOD 777 album_mod/upload
CHMOD 777 album_mod/upload/cache
CHMOD 777 album_mod/upload/med_cache
CHMOD 777 album_mod/upload/otf
CHMOD 777 album_mod/upload/wm_cache
The steps below are not required unless you enable the Nuffload Upload feature via your ACP
You can safely skip this step for now, it you want.
Change "Path to cgi-bin" in Admin CP to a relative path from phpBB root to your cgi-bin
Create folder: cgi-bin/tmp/
copy cgi-bin/nuffload.cgi to cgi-bin/nuffload.cgi
CHMOD 777 cgi-bin/tmp/
CHMOD 755 cgi-bin/nuffload.cgi
This step will create your tables, etc for you....remove the file after you successfully run it.
Copy "fap_install.php" to your phpBB root and execute it from your browser when you're logged in with admin rights
That should do it .... hope I didn't leave anything out
Good luck .... let us know
