Post Guest On FAP, Only Thumbnail Please
middiu wrote:
hi,
I want the guests only to see the thumbnails without the possibility to enlarge the pics
how can i do it?
thanks!
Artie wrote:
For your Mid/Full pics on register only. Try the code below.
I only tested this briefly, but seems to work ..... though, will not work if you have View full pic as a popup set to Yes in ACP
  2. ##------------------- [ OPEN ] ------------------------------------------------
  3. #
  4.
  5. album_showpage.php
  6.
  7. #
  8. ##----------------- [ FIND ] ----------------------------------------------------
  9. #
  10.
  11. // ------------------------------------
  12. // TEMPLATE ASSIGNEMENT
  13. // ------------------------------------
  14.
  15. #
  16. ##--------------- [ BEFORE ADD ] -----------------------------------------------------------
  17. #
  18.
  19. if (!$userdata['session_logged_in'])
  20.     {
  21.         redirect(append_sid(album_append_uid(LOGIN_MG . "?redirect=album_showpage.$phpEx&pic_id=$pic_id")));
  22.     }
  23. #
  24. ## --------- [ SAVE FILE ] ---------------------------------------------
  25. #EoM
  26.
Artie - View user's profileSend private messageView user's personal gallery
Thanks for the useful Topic Artie:
buldo (09 January)
Post Re: Guest On FAP, Only Thumbnail Please
Great,
maybe there should be a switch in ACP for this.
Good suggestion... when I have some free time I'll do it...
The same modification should be applied to album_otf.php, album_picm.php and album_pic.php otherwise someone may access directly to the pic...
Remember that BBCode posted pictures in full mode may be affected as well.
No there's something I never would have have thought of.
I now know why you make the big bucks.
Artie wrote: [View Post]
Ha ha ha... Usually there is even something I forgot... just wait that someone will read this and found what I missed...
I want use it for view profile. How can i do?
EDITED:
I have used this:
       append_sid('LOGIN_MG. "?redirect=profile.' . $phpEx . '?mode=viewprofile&u=' . $user_id );
it seems to work...
Gianni PB - View user's profileSend private messageVisit poster's website
in 1.1.9.24 it doesn't work in profile.php
why?
