Post Convert Icy Phoenix To phpBB?
Well I am trying to do that but it doesn't work.
I have got 1.3.0.53a and I want to do it because I want to try vbulletin.
I want to convert to phpbb2 and then to vbullentin, but I have got this error:
Warning: include(./../extension.inc) [function.include]: failed to open stream: No such file or directory in /web/htdocs/www.clubsunroller.com/home/foro/install/clean_tables.php on line 25
Warning: include() [function.include]: Failed opening './../extension.inc' for inclusion (include_path='.:/php5/lib/php/') in /web/htdocs/www.clubsunroller.com/home/foro/install/clean_tables.php on line 25
Warning: include(./../common.) [function.include]: failed to open stream: No such file or directory in /web/htdocs/www.clubsunroller.com/home/foro/install/clean_tables.php on line 26
Warning: include() [function.include]: Failed opening './../common.' for inclusion (include_path='.:/php5/lib/php/') in /web/htdocs/www.clubsunroller.com/home/foro/install/clean_tables.php on line 26
Fatal error: Call to undefined function message_die() in /web/htdocs/www.clubsunroller.com/home/foro/install/clean_tables.php on line 48
How I can solve it?
Thanks for all your work...
AnakinSend private messageVisit poster's website
Post Re: CONVERSION - How To Convert Icy Phoenix To PhpBB 3
you can port Icy .53 directly to PhpBB3. there´s a script for doing that.
It consists to install PhpBB3 clean on a subfolder off your IP root for example, afterwards upload the requiered script to PhpBB/install/converters and go to install again.
there you select conversion. select the IP converter and run it
fill the requiered data in and wait to the time the script finishes.
afterwards check, that everything was portet, by checking your PhpBB forum.
Be aware, that you´ll lose installed Mods and they´re Data
icp_13053a_v100.zip
Filename: icp_13053a_v100.zip
Filesize: 26.14 KB
Downloaded: 350 Time(s)
thanks, i will try it.
but, how i have to configure database?
a new data base or the same dsatabase?
What about prefix?
you configure a new BD, leaving the IP one intact
prefix does´nt matter, since during conversation, prefix will be changed or imported.
on the conversion page, you´ll be asked for the  User , pass and prefix of your IP bd
conversion takes about 20 minutes, if you got a medium sized BD ( lets say 100mb)
One thing. after conversion, you´ve got to rebuild search tables via PhpBB admin panel
Another question, how I can to maintenance two forums?
I only will try phpbb3. So I want to left icy phoenix as before.
Can I work with a copy?
Yes, because your IP database remains untouched and unchanged.
you can run the PhpBB on a separed domain or subdomain.
But , if you post something in PhpBB , the ip wan´t be updated with that and viceversa
well I have got a lot of problem to convert my icy-phoenix forum to vbulletin.
First I converted to phpbb3 and then to vbulletin, but it doesn't work well.
In phpbb3 I haven't  avatars for example, and smiles.
is this the only problems you got ??
because i converted an Icy to PhpBB3 and afterwards to VB without much problems.
BTW maybe one of the admins can split this, and move it to General, since i just noticed, that where discusing in DOC section, starting on post #11
spydie wrote: [View Post]
Done
Post Re: Convert Icy Phoenix To PhpBB?
Thx
Well, lot of posts lost.
and attchement lost.
I think I will stay with icy phoenix.
Altaught I am looking for mobile style, automatic and facebook connect, and more things....
wait for new release then.
There´s an Mobil style for it.
FB connect is a bit more dificult, since FB is changing the API all the times.
I converted an Icy to PhpBB and afterwards to VB without any posts lost.
looks like you commited an error somewhere
Post Re: Convert Icy Phoenix To phpBB?
I didn't know there was an official convertor for Icy Phoenix to phpBB 3... thanks for sharing spydie.
Can I have a link where did you find that?
I found that a time ago on PhpBB.es but I´m not shure that it is still there.
last time i searched for it there, i could´nt find it again.
As far as i know, That´s a job from YuanManWe and others from PhpBB.es
D¡cky » Mon Apr 05, 2010 5:00 am wrote:
Version 1.0.0 of the Icy Phoenix to phpBB3 convertor is attached. This convertor was written for Icy Phoenix version 13053a. I don't believe it is compatible with earlier versions of Icy Phoenix. Icy Phoenix 13053a has many of the features of phpBB3 and most of these will be converted over to phpBB3.
Many of the Icy Phoenix BBCodes will be added automatically by the convertor. Some I was not able to do because they require additional javascript files or additional MODs, e.g., albums.
Optional is the conversion of Genders. If you would like Genders converted, you will need to install the Gender MOD. If not installed, the convertor will skip converting genders.
http://www.phpbb.com/community/view...13305#p12513305
icp_13053a_v100.zip
Filesize: 26.14 KB
Downloaded: 324 Time(s)
