Post FAP SUPPORT - Album_upload.php - Permission Denied
Hi there,
I get this error while trying to upload a photo.
Permission denied in /album_upload.php on line 873
failed to open stream: No such file or directory in /album_upload.php on line 893
I have checked the permissons and they are set correctly!
jzSend private message
Post Re: Album_upload.php - Permission Denied
Here on this site or elsewhere?
May I have a link please?
my test site
http://forum.kaltersiashqiptare.com/album.php
jz wrote: [View Post]
my test site
Hey guys,
has anyone had a chance to have a look at this?
Definetly a permission problem.
Have you tried removing the .htaccess files ?
ArtieSend private message
yes I did same error...
Try re-uploading album_mod/**all files**
or it may be album/**all files**
I can't look because I reformatted earlier and haven't reinstalled my ftp client or any of my files yet
Also recheck and make sure that all permissions are done after reuploading
Hello, I'm your mind, giving you someone to talk to.
Black Fusion - Designs
..Join.My.Vampire.Family..
FrostSend private messageVisit poster's website
I have done that too, I have re-aplied the permissions also.
Maybe I'm missing a folder or something.. can you guys take a look at the folder structure in the pic attached?
Description: snap
Filesize: 22.84 KB
Viewed: 24070 Time(s)
Well, in my pafiledb folder I have an "index.htm" file and a "pafiledb_common.php" file
You have extra folders that I don't that you probably added, but other than that, you have all folders
Don't know what to say really...
I even re-installed the board and still get the same error.
Frost's suggestion was a good one. One thing I might add is delete from the server before re-uploading.
I had to do that in the past and sometimes had to repeat the whole process a few times before the CHMOD would take.
I think you have some improvement....yesterday, if I remeber correctly, I could not access any of the files directories.
Today I can access:
files
files/album
files/album/otf
also could not access:
pafiledb/uploads
Try to remove all HTACCESS in files folder and its subfolders... then let me know.
I did MG, no difference. have a look if you like
Sorry... as you know I've been away... did you solve this or is still unsolved?
no mate, no luck
This forum is locked: you cannot post, reply or edit topics.  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
