Post Viewing/Posting Bug? On this site
I tried to post this in the Bugs section but I couldn't post a new topic because I'm not a moderator so I'm showing here, and if it's a bug a Mod can move it
Place: General Support > update to ip problems By: -ktm-
Link: http://www.icyphoenix.com/viewtopic.php?t=852&highlight=
Error: The address you have requested returns a configuration error.
Errors has been registered to log file and we will check what the problem is as soon as possible.
Hello, I'm your mind, giving you someone to talk to.
Black Fusion - Designs
..Join.My.Vampire.Family..
FrostSend private messageVisit poster's website
Post Re: Viewing/Posting Bug? On this site
yes ame error for me...
moved to bugs so mighty can take a look
Play Games at GamesCampus!
Usually it happens when some user posts long pieces of code in a topic... only attachments should be used for posting big files...
I guess that the error is related to the Quick Quote feature... but I still need to understand where the problem lay...
I'll have some tests and I'll keep you informed if I can find a solution for this annoying bug.
By the way... as a guest you can see the topic.
