Re: [SOLVED] Quote First Post
This is your last post that I simply highlighted - copied - and pasted it here.
@mort
i don't understand what you say but the problem for me is solved partially because when the button is visible users can quote first post can copy url from img and all tag in the post
without button this they can not do so easily ...
All I need to do is add the "Quote" wrappers to it to make it a quote.
Like this:
@mort
So no matter what you do - If people want to quote the first post, they only have to copy the post and add the "Quote" wrappers.
That's why I said that no matter what you come up with - people can still quote the first post even though you may make it just a little bit harder.
maxweb wrote:
Hi, sorry for my english, i'm italian.
I want to remove the possibility to quote the first post of every topic from everyone with icy 2.0.
Is it possible?
You didn't say anything here about quoting img or url tags - just not quoting the first post.
As for disabling images in quotes, I thought that IP already had that option -
Or was that some other forum software I used to know. Either way it wouldn't be too difficult to add that to IP if it doesn't.
