Post Bug Add Uploaded Images To DB
Hi again
I have found other bug.
File: install/install.php
  1. // If you decomment this line, then you will be able to use this file without sessions handling in latest Icy Phoenix
  2. //define('BYPASS_SESSION', true);
If you use this option, you get this error
PHP Fatal error:  Call to a member function get() on a non-object in XXXXXXXXXX/foro.lapandadelcentollo.com/install/includes/functions_install.php on line 2747
$cache is not working
  1.                 if (($all_pics_array = $cache->get('_uploaded_images')) === false)
Bye
dinoyocoSend private messageVisit poster's website
Post Re: Bug Add Uploaded Images To DB
Hi dinoyoco,
I'm only guessing here but did you:
a. Rename the files/posted_images folder to files/images
b. Apply all permissions listed in Fresh Installation
Yes i know it. The question is if you use "BYPASS_SESSION",
  1. define('BYPASS_SESSION', true);
you will get the error. But if you don't use "BYPASS_SESSION",
  1. //define('BYPASS_SESSION', true);
you will not get the error.
Bye
Can you try this?
OPEN install/common.php
    include(IP_ROOT_PATH . 'includes/utf/utf_tools.' . PHP_EXT);
AFTER ADD
    include(IP_ROOT_PATH . 'includes/class_cache.' . PHP_EXT);
    include(IP_ROOT_PATH . 'includes/class_cache_extends.' . PHP_EXT);
    $cache = new ip_cache();
Thanks, now it works.
Bye
Great... I have amended it.
Thanks for reporting.
