Post Skins In Development
This is where I will show the next three skins in development for Icy Phoenix.
Each set will contain the images/features of the three skins inside that set. I will be updating and/or removing images/code/features constantly as I go through the process. You are more than welcome to suggest anything you'd like to change or see with each skin. I guess you could these "open source" skins
Anyways I am going to post this explanation and then reserve the next three posts after it so that I can post the skins in order. I've asked permission from MG to do this.
The skins will be numbered 1 - 3 in order of appearance.
Any member can post ideas, thoughts, images, etc and they will be taken into consideration. If any of your contributions get used for the final release of the theme, you will be included in the Author/Thanks section
Let's make some skins!
Hello, I'm your mind, giving you someone to talk to.
Black Fusion - Designs
..Join.My.Vampire.Family..
FrostSend private messageVisit poster's website
Post Re: Skins In Development
Skin 1
Theme: bf_touchscreen
Info: This theme is based off a touch screen panel and will have similar features. Mouse-over effects like glow and illuminate. Skin is given a flat smooth look, with the button or "touchscreen" areas flush and glassy looking
JS/Code Used: CSS navigation for top menu, opacity hover effects for "glow" (more to come?)
Program/Format: Photoshop CS2/.psd available for update/fixes
Preview 1. Jan 10 2007  www.black-fusion.com/media/bf_touchscreen.jpg
Preview 2. Jan 12 2007  www.black-fusion.com/media/bf_touchscreen2.jpg
Demo: Not Yet
**Reserved**
Skin 2
**Reserved**
Skin 3
I like your design I wait that you should put it to discharge when it is ready
joni806Send private message
They will all be released exclusively on this site or mine when they are finished
I will also probably do "extra" graphics for all the skins I do, like different style blocks or headers or something
Might even do custom headers as long as it's asked here on this site
ok pardons by my English but use a translator I believe that it is understood to me not if absolutely but I believe well that if
would you used rounded corners?
is nice but with rounded corners should be better in my opinion
sonoangeloSend private messageVisit poster's website
Ok,
When I get home from work tonight I will redo it with rounded corners
You want rounded corners on the header area too?
I also will redo the blocks images, i don't like those now that I've had sleep
Damn they're pretty nice
I can't wait
Life's a bitch and then you die, that's why we get high,
Cause you never know when you're gonna go.
MiguelSend private message
Thanks Frost, we look forward to check your work in progress!
The first template you have just inserted as a demo, is cool... I think I would only remove the CYAN glow around the table headers... but I'll wait the final layout before saying what I don't like!
Yea, I dasasashk
Off Topic
^ That is the result of a POS wireless keyboard/mouse combo I bought. The repeat rate is fu**** on it. I have to hold down the entire row of keys to make it stop... then it does it again. NEVER buy Micro brand anything LOL
Anyways... I don't like the boxes at all so I'm going to redo them LOL
I wanted to put something in the header area and menu area to "fill it out" but I am going to make a css menu for it...
I guess I could put a temporary layer there, and you guys could just delete it LOL
Going to go work on it now
Theme #1 edited and updated
Added rounded corners
Added different style blocks
Added demo text
Added gloss look
Ok what now?
lovely very very very very beautiful, when do you release it?
