Since the upgrade, I have also noticed that all new members since the upgrade, their usernames are HyperTexted. Same in the memberslist AND the profile in the forums??
Anyone know was this a change in format or something?
I think this is part of Color Groups. You can change that in ACP -> Groups -> Colorzie Group Names
If you remove the color association from a group or user, it should be back to normal.
____________ No support via PM or E-Mail!
FAP 3, yeah baby, yeah!
____________ ~~~Andrea~~~
User #379756 on Linux Counter
The time now is Mon 02 Feb, 2026 04:38 • All times are UTC + 1 Hour
